588,487 active members*
6,403 visitors online*
Results 1 to 5 of 5
    Jul 2007
    6
    Pp for DMU80 Monoblock 5 axis
    Hi All
    I need some help to finishing my Pp for this machine:
    -- Deckel MAO DMU80 Monoblock 5 axis continuos and indexed.
    ( C in the table and B in the head)
    For 5 axis continuos it is ok
    but for 5 axis indexed need some modifications, can someone show me a good PP? a little program to make one drill or pocketing!! I use the "Spatial Plane".
    I have some doubts in approach/retracts with RTCP...
    Thanks...
    Best Regards
    May 2010
    whats the system cam you use..
    i've postprocessor this machine ....but ... is NXCAM ..
    i used cycle def 19 / M128 plane spatial i'm not recomended.
    ANDRÉ LUIS DO NASCIMENTO
    SPECIALIST CAM APPLICATIONS MULTI AXIS / IS&V (NX)
    Jun 2006
    18
    Tommor i will send you the sample program with plan spatial angle, spatial angels are the advanced form of cycle 19, any way i will send you both of th programs.
    sent me you email.
    May 2010
    HELLO MY EMAIL Sohail is [email protected]
    I USE THE CYCLE DEF 19 INSTEAD OF PLANE SPATIAL
    I know well this CONTROL PLANE SPATIAL BUT I STILL PREFER THE CYCLE 19 AND M128 BUT IF YOU CAN SEND ME SOME EXAMPLES NO PROBLEM ..
    HUG !!!!
    VISIT MY WEBSITE cadcamnx
    Jul 2007
    6
    Hi andré
    I sent to you a example (to your e-mail), if you could help me I would be grateful.
    Thanks...
    Best Regards
  1. DMU60 monoBLOCK 5 Axis
    By FuzzyDuck in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-04-2009, 02:41 PM
  2. post for 2 axis ez trak versus 3 axis ez vision
    By tooolman in forum G-Code Programing
    Last Post: 11-28-2008, 10:33 PM
  3. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  4. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors / Drives
    Last Post: 02-07-2008, 07:38 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
