588,410 active members*
5,056 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Z axis faults and falls to table
Results 1 to 12 of 12
    Nov 2010
    My '89 Fadal 4020 decided to start acting up today by faulting out the axis' and then the head slowly falls to the table. I reset the e-stop fault, return to "home" and the problem eventually repeats itself. What may be causing the head to fall down to the table? I can understand the axis faulting out and sitting idle (which it's always done in the past) but now the head falls and e-stop does nothing to stop it! Thanks in advance for any advice.
    Jan 2006
    64
    imaginemw,
    Will the head continue to go down if the main power switch is off?
    Apr 2005
    1194
    Typically this means a counterweight pin was left in after moving.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Nov 2010
    Yes, it has fallen with the power off.
    Nov 2010
    ......I found a relay loose, reset it, and so far the machine seems happier today. I'll keep you posted.
    Apr 2005
    1194
    Must be a TRM or EMC
    Nov 2010
    Well the relay fix was too good to be true. The problem has reared it's ugly head once again. Any ideas?
    Apr 2005
    1194
    Which machine was it?
    Nov 2010
    It's a '89 4020 Model 904-1. I've kept it powered up for last day or so and now today it's seems to be running fine. Do I possibly have caps going bad? Losing power after being powered down for a few days?
    53
    Your gib straps are loose. Look in the maintenance manual for the procedure.
    Nov 2010
    Will do. I'll keep you posted. Thanks.
    Nov 2010
    Update....I adjusted the gibs (way loose!) and replaced a bad amp board. I'm and up and running again. Thanks for the help.
  1. Taig headstock falls
    By littleCNCjohn in forum Benchtop Machines
    Last Post: 08-30-2011, 01:43 PM
  2. Z axis falls down when power turned off.
    By gorillam in forum Uncategorised MetalWorking Machines
    Last Post: 03-06-2010, 11:02 PM
  3. Y axis resolver/over temp faults
    By smittys800 in forum Fadal
    Last Post: 06-11-2009, 05:57 AM
  4. Replies: 7
    Last Post: 10-24-2007, 08:08 PM
  5. Tooling Falls off Racks?
    By nonnsgranite in forum Material Machining Solutions
    Last Post: 08-02-2006, 08:09 AM
