587,287 active members*
3,955 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Wave Panel need help!!!!
Results 1 to 9 of 9
    Sep 2005
    17
    I have a project to recreat a wave panel. The template I have is approx a 24"x120" pattern. I need to make it 48"x120". The problem I am having is that all 4 edges of the panel are different. So I can't just copy the pattern next to it. I will attach a pic of the panel. Also if any one can help I have an autocad file.
    Sorry i dont know how to attach the pic so if any one is interested I will e-mail it to them
    Shawn
    35538
    Ckick the "Manage Attachments" button to attach pics.
    Sep 2005
    17
    thank you.
    35538
    Could you post the AutoCAD file? 2000 format, if possible.
    Sep 2005
    17
    I would but the file is about 8-9 megs after it has been zipped.
    35538
    Can you upload it somewhere?
    Sep 2005
    28
    Hi John
    With my software I can view your model but cannot modify it in any way.
    I assume this in a decorative pattern where the actual dimensions are not critical.
    My suggestion is this:
    Rotate the model until the waves are horizontal (about 3 deg)
    Trim the pattern until you have only one horizontal wave.
    Trim again until you have only one vertical wave.
    Copy translate along x and y many times to cover a large rectangle.
    Rotate the pattern back (about 3 deg)
    Trim the new pattern to the required larger rectangle.
    Dec 2014
    3
    Re: Wave Panel need help!!!!
    can you email me the dwg or dxf file?,i maybe to help you
    Jan 2006
    2985
    Quote Originally Posted by hansbob View Post
    I'm guessing he found a solution some time in the last 9 years!
  1. Wave relif needed
    By mytheron in forum WoodWorking Topics
    Last Post: 01-05-2013, 09:18 AM
  2. Sine Wave
    By flannman in forum Rhino 3D
    Last Post: 08-20-2011, 03:53 AM
  3. Miller 180 syc wave tig
    By larry53 in forum Welding Brazing Soldering Sealing
    Last Post: 02-08-2008, 04:02 AM
  4. Wave cut rougher?
    By kesparate in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2007, 08:47 PM
