588,585 active members*
13,754 visitors online*
Results 1 to 19 of 19
    Oct 2006
    26
    Yaskawa Software
    Hello Everyone,
    I am building a CNC table and using Yaskawa Servo's but I can't seem to find where I can download the software on Yaskawa's site for this older model. Its an SGD-02BS amplifier. I have tried their new software, Sigma win-lite and even the old dos version SVMON which still doesn't list the SGD amps, just the SGDA's and newer.
    Any help would be appreciated.
    15362
    dlktdr
    You may need a hand held programer, to do those drives, I would try the SGDA programming software first, as the hand programer may be hard to find for those drive's as well
    Mactec54
    Oct 2006
    26
    Yeah using SGDA just tells me its the wrong drive and to select the correct one, Sigma win just shows Unsupported Drive and the new one doesn't scan a thing. I know there is software somewhere for it I have used it on an old Flow controller quite a few years ago. It was a dos based version of SVMON but had SGD listed... Just wish I kept a copy..
    I might just have to contact Yaskawa and wait... or just buy another Sigma 2 off Ebay.
    Oct 2006
    26
    Solved
    Well like everyone tells you Google it. I rephrased the search and found a copy of the old 2.1 version with SGD servo-packs in it.
    http://www.yaskawa.com/site/dmservo.nsf/link2/DCAN-6GTP83/$file/SVMON_2-1r3.zip
    Thanks..
    15362
    dlktdr
    Glad you found it, Yaskawa still have most of the information on Drives/Motors at there site, it just takes some finding sometimes, By your first post I thought that you had tryed SVMON software
    Mactec54
    Oct 2006
    26
    I had tried the SVMON software. The version I found first is 3.5r2 but it doesn't have the older drives. The 2.1 version I found later did..
    Now onto other issues... You can't monitor alarms, or manual jog in the software with these older ones, I guess I'll have to open the connector and check the alarm outputs to see why it's faulting on servo on...
    Buying another Sigma 2 motor is sounding better and better.. On the plus side I know the constants are correct now.
    15362
    dlktdr
    You may find something in this PDF that may help you
    For jog you need the digital operator
    Attached Files Attached Files
    Mactec54
    Oct 2006
    26
    Alarm showed an encoder fault... Accidentally hooked up +5 and ground wrong in the connector... luckily it didn't damage anything.
    And all works now. Thanks for the advice.
    15362
    dlktdr
    That was a lucky one, that the 5v was going to ground,
    I think others would like to know as well, what wires went to the pin numbers you used & for what each wire did, if you have them, & have the time to post them, I'm sure it would help others doing these plugs as well, I know a lot of people have problems wiring the drive plugs
    Mactec54
    Oct 2010
    Growling Yaskawa
    I just wired a Yaskawa SGD-02BP drive and SGM-02B314 motor.
    The motor growls but doesn't turn. I don't have a JUSP-OP digital operator so am using SVMON 2.1 MS-DOS software. An alarm on the servopack drive appears after 5 seconds and the growling stops. The CN1 cable is disconnected. I feel like I'm missing something basic... and I don't want to fry anything.
    Thanks for any words.
    Attached Thumbnails Attached Thumbnails SGM-02B314_a.jpg   SGM-02B314_b.jpg   SGM-02B314_c.jpg
    Aug 2006
    15
    SVMON 2.1
    Hi.
    I have also an old SGD driver and I need the SVmone 2.1.
    The link to Yaskawa web is broken.
    Can you please upload it ?
    Meir Mark
    Oct 2006
    26
    Here it is...
    SVMON2.zip
    Aug 2006
    15
    Svmon 2.1
    Thank you very much.
    I have a problem runing the prog, when I start I get an error "MOTOR.TBL was
    change".
    After pressing OK I get an error "SGDP.TBL was change.
    Can you please check if it is working for you ?
    Svmon V3.5 is working nice but is not compatible with the SGD drive.
    Meir Mark.
    Jan 2012
    Red face
    Hi, I'm a new member to the CNCZone. I found your forum with "meirmark" very helpful, I have exactly the same problem as "meirmark" so I downloaded your link for SVMON2.zip. As soon as its runs it comes up with "Table file MOTOR.TBL was change. Install table file to PC from backup disc" After I click OK and select my servo model "SGD**-AP" I get a similar message, "Table file SGDP.TBL was change. Install table file to PC from backup disc". Any ideas?? I started to write my own version of this program a few years ago and frustratingly I didn't get very far so I was extremely happy to hear of SVMON2.1. Please help! Martin
    Feb 2009
    6028
    Have you tried the latest software available from yaskawa? I just downloaded it last week and used it without problem on a mid 90s flow water jet. Worked perfect.
    Oct 2006
    26
    Looks like the software checks the time stamp of the file and wont open if it's not correct. Here is a new zip with the proper time stamps
    http://www.powerautomation.net/download/SVMON_2-1r3.zip
    Jan 2012
    IT WORKS!!!
    Thankyou very much!!!! You have saved me hours of work. Martin.
    Oct 2011
    Thanks for all the information everybody has brought.
    I tried the svmom 2-1r3.zip and it has the same errors as the first.
    Any idea what I am doing wrong?
    Thanks again.
    Nov 2017
    6
    Re: Yaskawa Software
    Quote Originally Posted by dlktdr View Post
    Hi everybody!! I'm looking for rs232 pinout connection for SDG-08VH, somebody can help me?
    Thank's in advance
    Andrea🇮🇹
  1. Yaskawa SGM and SGD
    By cwalker1960 in forum Servo Motors / Drives
    Last Post: 03-24-2013, 05:05 PM
  2. yaskawa
    By outctrl in forum Servo Motors / Drives
    Last Post: 09-16-2009, 02:05 AM
  3. Yaskawa servopack
    By Grubma in forum Servo Motors / Drives
    Last Post: 10-22-2008, 07:54 PM
  4. Yaskawa help please
    By Arty 3000 in forum Stepper Motors / Drives
    Last Post: 02-20-2007, 05:35 PM
  5. yaskawa help please
    By h_2_o in forum Servo Motors / Drives
    Last Post: 11-20-2006, 02:01 AM
