587,472 active members*
3,016 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Illegal Expression in line
Results 1 to 10 of 10
    Jun 2009
    146
    If I On FADAL 4020 write this program:
    N1 G21
    N2 G1 X-50 Y50 Z-50 F2000
    N3 X50 Y-50 Z0
    N4 #GOTO N2
    N5 M2
    I have the Error message: "ILLEGAL EXPRESSION IN LINE".
    What is wrong?
    Apr 2005
    1194
    That is because you are using BASIC programming language from the late 70s on a Fadal controller. #Goto N2 is not recognized as a valid expression. Check your Fadal manual and use the L number designation for repeat subroutines.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Jun 2009
    146
    Instructions which have been on the machine (PDF files), describing how to program in such a way...
    How to do an infinite loop above using the L word?
    On the computer of the machine, instructions are put equal to this:
    Sect_18_-_Macros.pdf
    May 2004
    4519
    Are you sure you typed in the letter O and not the number 0 in the machine?
    Jan 2006
    64
    Try using M99P2 in place of your GOTO call.
    Jun 2009
    146
    Quote Originally Posted by txcncman View Post
    Yes, I am sure!
    Jun 2009
    146
    Quote Originally Posted by Dyad1 View Post
    I tried to do so. Such works, thanks!
    Jun 2009
    146
    How can I then use "IF" comand?
    For Example:
    # IF V1 > V2 THEN GOTO :N5
    Controller is FADAL CNC 32MP. The controller has commands translated into German. Are maybe command by the programming in the German Language also?
    Jun 2009
    146
    Is it possible on my Machine working with "If" Comand?
    Is that maybe impossible?
    Jun 2009
    146
    Whoever?
    "If" word on this mashine is possible?
  1. 065 Illegal command in G71-G73
    By jdgromi in forum Fanuc
    Last Post: 12-15-2008, 08:45 PM
  2. 032 illegal offset value in G10
    By mr-seiki in forum Mori Seiki lathes
    Last Post: 10-15-2008, 08:11 PM
  3. SHOWDOWN! - Adobe Dreamweaver VS Ms Expression Web ?
    By thkoutsidthebox in forum Community Club House
    Last Post: 01-21-2008, 03:53 PM
  4. Replies: 0
    Last Post: 09-12-2007, 07:08 PM
  5. Mazak Expression
    By iNk in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-17-2006, 05:01 AM
