587,957 active members*
3,635 visitors online*
Results 1 to 20 of 20
    Dec 2003
    673
    220v Switches for CNC lathe build..
    Seems dumb, but where do I get switches for my cnc lathe conversion? I'd like good quality stuff, and e-stop, a good sized (1.4-2") 3 position rotary switch for Forward, off and reverse, and a big panel mount light to show that the lathe power is live.... Seems should be easy to find, but have spent some time googling and not seeing what I need.
    Thanks.
    Dec 2003
    24220
    What kind of motor are you reversing?
    Switchgear & panel switches and indicator lights such as Telemecanique is plentifull on ebay, also Allen-Bradly.
    Al.
    Albert E.
    Dec 2003
    673
    Al.
    its a grizzly 12x37. I think its 3hp... I have the factory switches, which used two switches and mechanical cams to select the switch, but I just finished the mechanical conversion of it to CNC and took all the non-essentials off. I need to replace those two momentary contact switches with one rotary switch. Off in the middle, reverse to the left and forward to the right. It has a light too, but it burned out immediately when new.
    Nov 2006
    25
    Grainger has lots of switches and e-stop buttons and lights.
    Most of the lathes I own use a drum switch.
    Grainger Industrial Supply
    e-stop
    Search e-stop buttons - Grainger Industrial Supply
    The Tormach machine website has some nice stuff in their parts section, mostly for milling but you might find something useful.
    Or you could try McMaster.
    Jan 2006
    2985
    Automation Direct has everything you need at discount prices. I have been happy with the switches and indicators I have bought in the past.
    Matt
    Apr 2008
    6
    I use Allen Bradley 800 series switches for all my panels ... nothing better IMHO. eBay is your friend if you are patient. Cheers, Bill
    Dec 2003
    24220
    I found the Telemecanique ZB2 series a bit less clunky, and they are also very numerous on ebay, also if you want a motor reversing contactor they come in DIN size/mount.
    Al.
    Albert E.
    Feb 2009
    6028
    for what it's worth, US code now is low voltage controls. That means 110 or lower for operator push buttons, lamps etc. Thats why its hard to find 220 indicating lamps and 220 volt coil contactors.
    Dec 2003
    24220
    Personally I use 24vdc for all control circuits.
    Al.
    Albert E.
    Feb 2009
    6028
    Al.
    I'm 100% with you on that.
    Dec 2003
    673
    Thanks for the tips guys.... Lathe is a G2949 and looks like the controls are 24v. Here's the machine so far. I got the mechanicals done, but am a bit chicken on the electrical. I'm sure I make it harder than it has to be. I have a kill sw, and really just need a new forward/reverse switch arrangement.
    Automation direct seems to have decent stuff/prices - I looked on ebay, but not exactly sure I'm getting the right stuff. Could you guide me on the forward reverse switch? I'm thinking this switch
    GCX1370-22 Products
    But not sure how to wire that from what I have now - the pic is the current switch arrangement for Forward reverse (off is just not touching either switch)
    Attached Thumbnails Attached Thumbnails IMG_1144.JPG   Screen Shot 2012-02-06 at 9.30.59 PM.png
    Jan 2006
    2985
    Quote Originally Posted by Spinnetti View Post
    GCX1370-22 Products
    That is exactly what you need, with 2 NC and 2 NO contacts. Each side will have 1 NO and 1 NC. You can connect one terminal from each block together, that will be your common, then you will have a C, NO, and NC for each switch position with center being off.
    I can draw a picture if you need it, but your link is the exact thing you need assuming it fits the cutout and you have enough space behind the panel to fit the double stacked contacts.
    Matt
    Dec 2003
    673
    Quote Originally Posted by keebler303 View Post
    Matt
    Thanks Matt... I'l order up the switch. I'm making a custom panel anyway over the z-axis motor, so space won't be an issue. I'll post back when I figure it out, or get lost again!
    Thanks for the help!
    Jan 2006
    2985
    Hook up the contacts like this and it will be straight forward how to replace the old switches.
    Matt
    Dec 2003
    673
    Matt
    Thanks Matt! Switch on the way along with a optical pickup so I can get spindle speed for threading....
    Feb 2012
    Dec 2003
    673
    Sorry to be dense... could you guide me to make sure I don't blow something up?
    I got my switches in (good call on the vendor!).
    Matt, Here's how my switches are wired now for forward and reverse. Can you confirm for me how that matches to your picture? I put numbers on them to make it easy, like 1-2, 2-3 kind of thing...
    Thanks!
    Attached Thumbnails Attached Thumbnails Screen Shot 2012-02-06 at 9.30.59 PM.png
    Jan 2006
    2985
    Thanks!
    Lets say there is a left switch and a right switch, like my drawing. The black lines are wires. Just match up the labels on my drawing to yours. With your new switch, you have to make a 3 pole contact out of the separate 2 pole NO and NC. If you connect one terminal of each together, like my drawing shows, that becomes your COM terminal. Then its just a matter of matching up the contacts from your drawing to mine.
    my left NO = your left NO
    my left COM = your left COM
    my left NC = your left NC
    Same for the right.
    Matt
    Dec 2003
    673
    Same for the right.
    Matt
    Gotcha.. I'll try it tonight...
    Thanks.
    Dec 2003
    673
    Thanks everybody!
    Just wired it up. Worked first try except switch direction was backwards, so swapped the two N/O wires and its good to go. Thanks for the advice! Now, just need to make up a new control console and mount up the new switches....
  1. anyone have 220v servos?
    By xclr82xtc in forum Servo Motors / Drives
    Last Post: 06-14-2010, 10:31 AM
  2. switching a 440v lathe to 220v
    By dannystooblue in forum Phase Converters
    Last Post: 01-28-2008, 07:24 PM
  3. which 220v mig to get?
    By keebler303 in forum Welding Brazing Soldering Sealing
    Last Post: 12-14-2006, 04:06 PM
  4. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
