588,496 active members*
4,373 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > 0 - 90+ volt variable DC power supply
Page 1 of 2 12
Results 1 to 20 of 21
    Sep 2005
    16
    Everyone needs a variable power supply for bench testing of your motors right? Well, a lot of the motors out there seem to run on 12 & 24V, which is no problem, but what about the ones that take 90V? Must you make/buy a separate power supply for each one?
    My goal right now is to run some 24V brushed DC motors (Yaskawa Minertia R-series servo motors). The data sheet (for the 50 oz-in one) specs the stall current at ~28 amps IIRC, which would dictate my overall power rating I would think. However, if some higher voltage (i.e 90 V) DC motors come along at a later date, it would nice to be able to run them off this same supply as well.
    I've considered going the PWM route, with 90VDC as the rail voltage, but have concerns about such a large square wave pulse if used with lower voltage motors, even if the duty cycle provided the appropriate "RMS" voltage. And if I used a 24 V rail voltage, then it wouldn't be capable of driving a 90 V DC motor I wouldn't think.
    I was thinking of making a linear power supply to have the capability of running any range of voltages between ~0 and 90+volts DC. Anybody do this before? The vast majority of one's I've seen out there go ~1.2-36 VDC (probably for good reason, I'm just not experienced enough know why)
    After trying to find some multi-tapped transformers that would provide the appropriate levels of AC, I started thinking about using a variac to supply 0-120 VAC, followed by a diode bridge rectifier of appropriate maximum rating, and some fairly large filter caps dictated by my max voltage (rectified 120VAC). This would provide an unregulated source of DC. I haven't thought through how to regulate anything above 36V yet, but.....
    I was considering using an LM317 voltage regulator (~1.2V - 36V IIRC) that would be switched into the circuit for cases where I was needing voltages below 36V, to provide much better regulation without a lot of fuss. I haven't checked the current capacity of the LM317 yet, so it may not be up to the task. Perhaps if I lower the current requirement to ~3-5 amps @ 24V (since I won't be using this to power the system, just want to bench test the RPM/volt spec on the encoders, probably under minimal load), this would become more practical?
    I haven't thought through cases higher than 36V yet -- would the unregulated supply have a LOT of voltage droop under load at, say, 90V?
    Again, I haven't considered all the details of this design yet, I was just wondering if you folks tend to draw a line between 0-24 VDC and the "higher-voltage" motors and get different power supplies for these two cases.
    Chad
    1695
    A linear reg is too inefficient. Why not use a switching supply? A discarded PC supply will have most of the parts, if you're ambitious.
    Nov 2004
    131
    The lm5007 is a 80V regulator, www.national.com/pf/LM/LM5007.html, but it's only 700 mA.
    Maybe you can put a power transistor over it. I know you can do this with the 78xx series.
    I also saw somewhere on www.headwize.com (or another forum about tube amps) some guys using a regular lm317 with lots of diodes between the adjust pin and the ground.
    Every voltage drop over each diode equals the raise in voltage of the output.
    But again this is a couple of 100's of mA max.
    You also could make a giant batterypack out 1.5 V NiCd Cells.
    60 of them will give you 90 Volt in steps of 1.5 V.
    (And 60 switches, more then airwolf )
    ____________________________________
    Jeroen
    Dec 2004
    518
    I'd forget about switching in the regulator-just add a second, regulated output (or outputs) and leave the high voltage unregulated. Really, if you think about it, the only real purpose of the regulated is to feed electronics. So what, maybe 5 to 24 VDC at one amp?
    I'm doing the variac (10 amp) through a suitable bridge and 400 VDC caps. The goal is to be able to test various servo motors I come across. The one thing I read was that the ouput of the variacs isn't isolated from the line and that can present a hazard for electrocution. The advice was to use a 1:1 isolation transformer ahead of the variac.
    Lance
    Aug 2004
    244
    If you use a vaiac make for sure that it is a isolated type variac or you will let the magic smoke out of some expensive electroics. I speak from experiance, smoked a stepper driver and a motherboard in the computer.
    Sep 2005
    16
    I was actually thinking of using it to feed the motors, but maybe that isn't necessary.
    I don't see how the isolated variac will save any of your electronics. I see it as a safety net between the variac and the wall outlet. I was originally thinking the isolation transformer went between the wall outlet and the variac, but perhaps it goes between the variac and the electronics??
    Maybe I'm not creative enough, but the PC power supplies I have seen have a 5V and 12V output -- perhaps you're suggesting a boost converter on the end of one of these. I don't know much about boost converters, but an interesting suggestion. However, I'm trying to avoid making this a bigger project than it needs be. I've never built a SMPS before, and although it would be interesting, perhaps another project for another day -- this (Linear supply) is more likely to be quick and easy and entirely sufficient, with the added benefit of not needing to worry quite so much about the effect that braking on the motor might have on the electronics. Since it will only be used for bench testing where the critical aspect is variable voltage to encompass a very wide range of motor testing, I thought a SMPS to be somewhat overkill. Yeah, it's inefficient perhaps, but it's not like I'll be using a voltage divider circuit to vary my voltage, nor will the supply be run continuously for long periods of time, negating any efficiency savings IMO. I'll save the SMPS for times when I want just a constant voltage -- or a source where I can interface a PWM (see my concern about PWM in this case in my first post).
    So perhaps voltage regulation isn't quite as critical as I originally thought. If I go the all-linear route, I don't think there will be any electronics on the board that will need to be powered from 5V, eliminating the need to figure out how to obtain 5V from the variac, or use a separate ac adapter.
    Chad
    Mar 2005
    10
    Now I'm using for my L297-L298 based stepper controller, a PC power supply. The 5VDC for electronics, and the 12VDC connected in series with two very cheap ($3.00 USD) transformers, these are used for home halogen lamps, they are 127VAC to 12VAC 50 watts , of course each has a bridge rectifier and a filter capacitor at the output. This way I have 12, 24 and 36 VDC, and I´m sure that you can do this up to 4 times more. May be this is not an ortodox solution, but it works very well with my 3.6 V 1,5 Amp, 200 steps/rev stepper motors.
    Jul 2005
    2415
    It may be overkill for what you want since it also features soft start, short circuit protection and other features but checkout the specs on our new ACM-01 module. It will handle 18V to 100VDC (regulated) at up to 2KW in a package a fraction the size of a variac. It needs an isolation transformer and controls the primary AC voltage. It's intended market is the big machine retro fits where big motors and lots-o-power are needed.
    http://www.CanCNC.com. Contact me off list for more details and pricing.
    Sep 2005
    16
    Posted by Manuel Bernal:
    My purpose is not to have several discrete voltages, but a continuously variable voltage output between 0 and 90V. Sorry if I didn't make that clear. Many times one (particularly those not extremely well versed in the art of electronics) wants to slowly be able to "ramp-up" the voltage to avoid a smoke-out of the electrical components
    Torchead,
    Yeah, that would probably be overkill for my application -- With my ebay and digikey shopping, I'm currently looking at about $80-120 tops for the variac/rectifier setup. Size is not a huge concern with the variac.
    Chad
    Oct 2004
    590
    I recently purchased two power supplies on Ebay. One is a 24v 6amp switcher from General Signal (Solas) for $11.00 and the other is a variable linear supply from Raytheon (Sorensen) that goes from 0-80v , 2.0a for $40.00. Not the capacity that you're looking for but Ebay seems to be a good source for this kind of gear. I also have a Woodmaster planer in the shop that uses a 90vDC gear motor for the feed drive. It has a continuously variable speed conrol that works quite well but I don't know the motors current draw off hand.
    Jul 2005
    2415
    The supply is continuously variable from approx 18 to 100VDC at 20A primary current using a single pot but does not go all the way to zero. The auto transfomer is the cheapest way to go but just be aware that it has no isolation from the AC line so it's like putting a bridge across the AC. The DC - side could, with the wrong phasing end up being hot in relation to true ground (the part your body is at!). You just need to be very mindful of the way you connect the Variac and use the safety ground on the chassis so you don't light yourself up.
    I use a big variac to simulate varying line conditions on the bench. My scope chassis has ground floating through an isolation transformer BUT my plugin current probe (I found out after the sparks) is referenced to AC safety ground and grounded my scope when it's plugged in. I sent 10 ^ 6 AMPS through my logic circuit (for 100 usec) that had it's ground referenced to the AC hot side. Fortunately it wasn't through me.
    Even when you know what you are doing and being careful it's possible to have a lapse in focus.
    You also need to be aware that conventional linear regulated power supplies don't handle inductive loads (like motors) very well and the pass components can be easily destroyed by the inductive spikes or back EMF. Switchers on the other hand tend to get unstable if they happen to be driving a PWM motor control unless they have added caps on the output to deal with the highly no linear current loads.
    It's not easy to supply high current and high volts in a 0 - 90 VDC supply. There are circuits available to build PWM DC motor controls and several sold commercially and many show up on Ebay. I have one on my 120 Reliance Servo's on my big mill (80% converted to CNC). They just rectify and PWM the AC line but there is no isolation and yu have to be careful if you plan on using tested equipment!
    Mar 2005
    1498
    051005-0928 EST USA
    webbch:
    I suggest that you use a Sola constant voltage transformer to feed your Variac. As well as voltage regulation this will also provide electrical isolation from the ac line so you can ground one side of your bridge rectifier.
    A Variac will not give you fine resolution, but is a cheap way to get reasonable power and continuous adjustment from zero to max.
    You do not need an output filter capacitor. In this case at 120 v ac rms sine wave input your average dc output from a full-wave bridge is (0.636/0.707)*120 = 108 v minus two diode drops. A half-wave rectifier would give you 54 v minus one diode drop. If you have an output capacitor that is large enough that ripple is small, then the dc output voltage with said input is 1.414*120 = 170 v. A half-wave rectifier and adequate capacitor will give the same voltage as the full-wave bridge rectifier, but one less diode drop.
    For your lower voltage motors I would suggest a step down transformer on the Variac output.
    Aug 2005
    1622
    A lot of dc motor controllers show up on eBay for cheap. Check out the specs on these units to suit your needs. Many of them can be used with field or PM type motors.
    Most DC servo systems do not have regulation on the motor supply. The servo drives take care of that.
    Maybe someone could clarify PWM. I thought this happened on the low current side of the motor driver, not the output of the drive to the motor itself? Possibly different designs on this drive format?
    DC
    Aug 2004
    244
    What I mean by protecting electronics with a isolated variac is that you won't have ground loop problems. You can still smoke things and get shocked. I have used a non isolated varic with a bridge and cap to bench test dc motors with no problems. You must be careful with wiring of the variac and check the outlet you will powering from for proper line and neatral placement and make sure that the case of the variac has good ground for safety.
    Mar 2005
    1498
    051005-1107 EST USA
    One of Many:
    PWM stands for Pulse Width Modulation. This is not simply associated with input or output, or low or high power.
    PWM is a means to adjust the average voltage or current by rapidly turning on and off energy from a source.
    For example if you have a 12 v battery, a switch, and a load (motor). Create a circuit that will turn this switch on and off 20,000 times per second. Also create a means to control the percentage of time the switch is on per 1/20,000 sec. A motor load has an averaging time constant long compared to 1/20,000 second. So these pulses won't instantaneously change the motor speed.
    Suppose we want to control the average voltage to the motor. If the switch is closed 100% of the time, then 12 v is continuously applied to the motor. If the switch is never closed, then the motor voltage is zero. For a percentage between 0 and 100 there will be some average on-time value that will produce a given motor rpm and at some load. The percentage on time will be determined by the motor load and various electrical parameters. In a motor control feedback will be used to adjust the percent on time for the desired output.
    The PWM will be generated at low signal levels (TTL voltages) but will control the high voltage high current switches in most applications.
    You could consider a simple half-wave SCR dc motor control as a form of PWM. Here the period is 1/60 second. The inertia of the motor provides the long time constant, but you may hear a 60 Hz sound. This type of control is generating the PWM at the high power level, rather than using low level circuits to control the power switch.
    Aug 2005
    1622
    Gar,
    I understand what it is and what it does essentially. Part of the common misconception or differing breed I sometimes see mentioned, is that the motor ouput is modulated DC. I have used this type of system for heater controls, but not motors, so I cannot discount it completely. My concern was whether for discussion, we are talking about the same function to avoid confusing the two.
    From systems I have worked with. The input to the drive is what was modulated, but the output was a steady voltage and current source to the motor based on tach feedback for speed regulation.
    May 2005
    7
    Leeson DC motor controler. 113. from a local distributor. Variable speed and torque control. Comes with the speed pot. Acceleration/deceleration , torque, Min/Max speed onboard pots. 5.1A.
    110 and 220AC switch onboard
    Not sure if this is what your looking for, but thought I'd give you the inf anyways.
    Mar 2005
    1498
    051005-1406 EST USA
    One of Many:
    A normal dc motor is both a motor and generator simulataneously. If you rotate a dc motor with a fixed field excitation with nothing but a dc voltmeter connected to the terminals the terminal voltage will be proportional to speed. In a motor this internally generated voltage is called the counter-emf.
    If we assume no losses, then at a constant speed the internally generated voltage (counter-emf) equals the external voltage applied to run the motor.
    The armature coils have both resistance and inductance. Ignoring inductance as you mechanically load the motor power is required from the external power source and this causes a current to flow from the external source thru the armature resistance. This produces a voltage drop and thus the counter-emf is less and the motor speed is less. Theoretically this is a linear variation, and practically it is close to linear. Thus, motor terminal voltage is a good estimate of motor speed, and can be corrected for load.
    In PWM of a voltage source to control a motor you are really controlling the average current to the motor in short pulses from the switch. Because the armature coils have inductance you store energy in the inductance during the switch on time.
    An inductor will not allow you to instantaneously change the current thru it. When you open the switch the inductor will do whatever is necessary to keep the same current flowing. If you provide no path for the current then infinite voltage will be generated. In reality something will breakdown to allow current flow (arcing). So it is necessary to provide some path for this cuirrent. Many times this is done with a diode.
    This inductance effectively averages the current in the motor. The input to the switch is a pulse.
    Part of the input current is used to supply energy to the motor load and motor losses.
    May 2005
    7
    Quote Originally Posted by gar
    051005-1406 EST USA
    One of Many:
    The Leeson control can be outfitted to receive variable voltage from another source. It is on the same pins as the pot minus the third leg. What type of interface board would be required to control the motor speed from the computer? It sounds like this is what it's for, and it shure would be cool to get this running on all cylinders.
    Don't mean to jack your thread man...I can post outside if this is inapropriate.
    Mar 2005
    1498
    051005-1842 EST USA
    binary_d:
    I am not sure if your sentence with ? was directed to me.
    The speed control potentiometer probably produces an output voltage from 0 to 10 v or something like that.
    A very important question is whether or not this part of the circuit is isolated from the ac line. If it is not isolated, then you require an isolated device to generate the speed control signal.
    In either case you need some form of D to A converter (digital to analog) in or driven from the computer to supply this analog signal. Burr-Brown among others make isolated D to A converters.
Page 1 of 2 12
