587,395 active members*
3,714 visitors online*
Thread: Servo motor
Results 1 to 3 of 3
    Oct 2007
    37
    Servo motor
    Hello,
    I have a problem with one of my ac servo motor and I need someone to tell me what could be wrong. Now on to the problem. I purchased 4 new sets of servo motor and drives. When I recieved shipment I opend boxes and try to hand turn the motor shafts (motors were not connected to drives). One motor shaft didn't rotate smoothly. It's locking in 8 positions in one hand turn. Then I tested it with drive joging function and with my controller. Motor is vibrating when it's running by drive or controller. The other 3 motors are running smooth with no vibrations with the same parameters and connected to same drive. I have made two videos about this problem
    [ame=http://www.youtube.com/watch?v=ewqAP-l7jWQ]Bad motor - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=cOW_09c5b_w]Good and bad motor - YouTube[/ame]
    Peter
    Dec 2003
    24223
    If you can feel distinct indents as you turn the motor by hand and nothing connected it usually means a short somewhere in the motor?
    According to the first clip, that appears to indent much more than I would expect for a non-shorted motor?
    If you short the 3 terminals out on a good motor and try the same test, it should appear the same as the shorted one.
    Al.
    Albert E.
    Oct 2007
    37
    Thanks for answer Al. I have sent motor back to factory and I hope they will sent me new one.
    Peter
  1. Confusion between AC servo motor and DC SERvo motor
    By ishaqahmed in forum Servo Motors / Drives
    Last Post: 12-01-2011, 04:54 PM
  2. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  3. replacement motor for PML&Kollmorgen DC Brush Servo Motor
    By fymroger in forum News Announcements
    Last Post: 10-24-2008, 09:36 AM
  4. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
