603,344 active members*
3,287 visitors online*
Results 1 to 7 of 7
    Aug 2011
    X3 spindle C spanner size?
    Could someone tell me the size of the C spanners I will need for the X3 spindle nuts.
    Bob
    Feb 2012
    Bob,don't you have a digital caliper?
    Aug 2011
    Quote Originally Posted by HorridHenry View Post
    Yes, but I have not removed the spindle as yet. I thought someone would know the size so I can acquire the spanners before I start.
    Cheers, Bob
    Feb 2012
    I'm confused
    If you can see the nut and get a caliper on it then this will give the size.
    Aug 2011
    I'm confused
    I cannot see the nut until I remove the spindle.
    Feb 2012
    This is a pdf file to servicing the mill,Bob U don't kmow if it will help but its worth a look.
    http://www.arceurotrade.co.uk/projec...Guide.indd.pdf
    Aug 2011
    Thanks Henry - Yes I've looked at that. They look around 35 to 40 mm. I guess I'll just order a couple of 3/4" to 2" spanners. Cheers.
  1. G0602 Spanner Nut
    By photomankc in forum Benchtop Machines
    Last Post: 04-27-2011, 06:36 AM
  2. Need help with programming a spanner wrench
    By Shanghyd in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2009, 07:09 AM
  3. wanted er40 chuck and spanner please
    By dave g in forum Want To Buy...Need help!
    Last Post: 06-06-2008, 07:58 AM
  4. NMTB30 wrench / spanner?
    By damae in forum Bridgeport / Hardinge Mills
    Last Post: 12-14-2005, 10:45 PM
  5. anyone know what size spanner wrench?
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2005, 02:01 PM
