588,500 active members*
4,935 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > FREE 3D bas relief patterns for CNC!!!
Page 1 of 2 12
Results 1 to 20 of 31
    Aug 2003
    58
    Talking FREE 3D bas relief patterns for CNC!!!
    Hi everyone! :wave:
    I don't post much here in the forums, but I've been intermittently reading the forums since way back when CNCzone first started up years ago. I've been interested in building things since I was 2 years old! I built my own 4 axis CNC mill and 2 axis CNC lathe about 5 years ago by reading up here in the forums and other well known CNC related forums. And way back when computers first came out in the late 70s I've been interested in computer graphics. Which, eventually led me to the area of the difficulties involved with creating 3D bas reliefs for CNC. Being an artist, I focused for a few years on developing ways to do these and eventually came up with a few methods. The result is Patterns For CNC, my web site for distributing my 3D bas relief art.
    There you will find a few of the most highly detailed 3D bas reliefs than you'll find anywhere in the world. There is not a large selection because it takes form several weeks to a few months to create each one.
    Go there and download whatever you want completely anonymously for FREE! And if you find anything useful to you please make a donation!
    Jan 2006
    758
    Nice stuff...... shame this post seems to have been buried...
    Hi There,
    Nice models... look very much like artcam output.. and good of you to distribute for free...
    I also host some FREE relief content at cnc4free.org homepage... I generally try to upload about 25 new FREE reliefs each month.. but depends on other work... have about 600 reliefs online.. archived for the supporteters of my website...
    Anyway.. hope you keep up the good work and the FREE content distribution..
    All the best
    Danny
    What one man can do another man can do..
    BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
    Feb 2012
    74
    bas-relief from 3d scenes
    Please discuss how to create a bas-relief presented in the next video
    [ame=http://www.youtube.com/watch?v=ZXPn2PF_Wy4&feature=g-upl&context=G2f9be6dAUAAAAAAACAA]Digital Bas-relief from 3D Scenes - YouTube[/ame]
    Jan 2006
    758
    Certainly... happy to do so...
    Hi There,
    The models in the video are generated using the blender bas-relief composite node plugin... This first came to my attention circa 2008 / 2009..... It's a very good tool.. but unfortunately.. it's not easy to get it working....
    The plugin is specific to blender versions... it will run below blender 2.49 or blender 2.5... The plugin author.. and many others in the blender community have stated that this will not work in any version beyond 2.5...
    As the current blender version is 2.62 this means stepping back to one of the prevous versions.. blender 2.49 is the recommended blender version.. this is a considerable problem... The plugin author has made a blender 'build'available.. with the plugin pre-installed... not such good news as it may seem... you have to compile the blender build... to create an executable version that can use the plugin.
    Instructions are provided below to accomplish this...
    Building Blender with C++ Express and Scons on Windows XP/Vista
    Install the following Applications / Libraries
    1. MS C++ Express
    2. Python 2.5
    3. Scons
    4. Windows SDK for your version of Windows
    5. DirectX SDK
    6. TortoiseSVN
    7. Download /trunk/lib/windows from SVN (contains all the libs for windows)
    8. Download and copy the Quicktime Dev Kit to lib/windows/QTDEVWIN
    In blender/config/win32-vc-config.py
    set openexr path to lib_vs2005
    In windows Environment Variables
    Add the following paths (replace with your installation paths if different)
    PATH add c:\python25
    INCLUDE add C:\Program Files\Microsoft Visual Studio 8\VC\include
    INCLUDE add C:\Program Files\Microsoft SDKs\Windows\v6.0\Include
    LIB add c:\DX90SDK\lib;
    LIB add C:\Program Files\Microsoft SDKs\Windows\v6.0\lib
    Download SVN Trunk
    run scons from the Blender Folder.
    For ease, make this batch file This will update your SVN, and rebuild your checkout.
    c:
    cd\blendersvn
    "c:\Program Files\TortoiseSVN\bin\TortoiseProc"
    /command:update /path:c:\blendersvn\blender\ /closeonend:1 /notempfile
    cd blender
    call scons
    If you download multiple branches, change the build folder in config/win32-vc-config.py, but leave the install folder normal. Then in the /Sconstruct file at around line 317 there is a reference to env.BlenderProg(B.root_build_dir, "blender" change the "blender" to another name and that is what that branches exe will be called.
    I am not the type of person who gives up at the first hurdle.. and at some point I will perform the blender build process.... but in light of the complexity of 'building' blender.... I looked into the way the plugin works to see if there's an easier way to use this method.... there has been much discussion of this in the thread below....
    http://www.cnczone.com/forums/woodwo...ing_files.html
    As a result we have discovered means to emulate the function of the plugin.. without use of blender or any other complex tools / software install procedures...
    The models are created by a process that applies tone-mapping to a rendered depth-map of an existing 3D model... it's an image compositing process... when you understand the functions applied.. it's not so difficult to use the same method in generic FREE tools like kerkythea and gimp.... much easier than fighting your way through the install procedure above...
    Hope this helps
    Danny
    Feb 2012
    74
    new video
    [ame=http://www.youtube.com/watch?v=L5sffEExPU4&feature=g-upl&context=G2c6aeddAUAAAAAAAAAA]example.avi - YouTube[/ame]
    Feb 2012
    74
    Now Blender 2.62 is working on windows 7 is very stable
    Feb 2012
    74
    Oct 2010
    69
    Quote Originally Posted by yohudi View Post
    Hi There,
    Hope this helps
    Danny
    Hello Danny!
    You know.... I'm absolutely beginner in this area.
    I will have lot of questions, but step by step...
    First:
    For this process we need download Blender 2.95 (Windows) source code version. (2.49, or 2.49a, or 2.49b?)
    How need unpack it? How better? Simple unpack 2.49 directory to C: root?
    (C:\blender-2.49)
    Where I need put Bas relief node? Whitch files I need put for this?
    Where can we found the trully workable wersion of this node patch?
    I have ideas for these question, but better know it exactly. Usually my ideas are....
    Only in step by step. Sorry for my lame questions!
    Just another thing:
    Do you know something about this patch for 2.5?
    Topic:
    2.5 patch history
    Download:
    result: 2.5 patch
    Or as you told this version is not stable?
    Peter
    KisKZ
    Oct 2010
    69
    [quote=aues;1093051]Now Blender 2.62 is working on windows 7 is very stable
    Hello Aues!
    Thank you for your samples!
    I'm work on inserting your forum links on HobbyCnCArt.com into downloadable materilas with your name.
    I tried ask you on your homepage about buying tutorials, blender versions and others.
    Can ve meet directly here in private about this?
    Feb 2012
    74
    [quote=KisKZ;1095784]
    Quote Originally Posted by aues View Post
    Hello Aues!
    More info about video tutorial
    If you have any questions, I'm ready!
    Oct 2010
    69
    [quote=aues;1095836]
    Quote Originally Posted by KisKZ View Post
    More info about video tutorial[/URL]
    Hello aues!
    Sorry again my pure english! (We in Hungary call it: Hunglish. )
    My questions was before this post here on your page in comments!
    Just to clean all absolutely I quote these here:
    Hello Anatolii,
    Only a sort summary from me:
    This packet include
    - a Blender 2.49b with a bas-relief composite node patch. (Linux version?)
    - a Blender 2.62 (32 or 64 bit) with bas-relief compositing node patch for Windows XP, Vista, Vindows 7 (32 or 64 bit) (Working true and stable?)
    - Tutorials about building Blender with this node. (whitch version?)
    - Tutorials about using this node under blender from beginning to exporting objects, or maps
    - Tutiorials about using result of this node in other softwares.
    I can get it all if I buy your tutorial.
    Is it true?
    Have a nice day!
    KisKZ...
    other:
    Several users have reservations about.
    I think if you bought and try this package, then this could be two possible outcomes.
    First The others rely more and now you can buy your pack.
    Second if something could be wrong, then no one ever buys from you and no one will trust you.
    This is a good option for many people demonstrated in front.
    Finally become evident to everyone that your package is very good.
    Do you agree?
    Feb 2012
    74
    answer to the questions
    This packet include
    This package includes detailed instructions for creating a blender both 2.49b and 2.62 for Windows (not Linux), as well complete assemblies for Windows (not Linux) if the user will not be able to build your own!
    - a Blender 2.62 (32 or 64 bit) with bas-relief compositing node patch for Windows XP, Vista, Windows 7 (32 or 64 bit) (Working true and stable?)
    Yes! Works very stable!
    2.49 and 2.62 (32-bit and 64-bit for Windows - Not Linux)
    Yes!
    "Bas-relief.swf
    In this chapter we shows you how to get the height map in a Blender and processed it in Photoshop. Then we show in detail how to create a bas-relief out the height map in programs such as the Vectric Aspire, and Delcam ArtCAM."
    Is it true?
    Yes!
    Oct 2010
    69
    Yes!
    Correct answer.
    Oct 2010
    69
    Yes!
    Dear Aues!
    I got packet!
    For everybody, just for info:
    This packet is work! I tried it and with my very pure experience in bleder (2.62!) I'm made my first simle bas relief only some minutes later!
    With Blender 2.62 under Windows7!
    Thank you for your work aues!!!
    Peter
    KisKZ
    HobbyCnCArt
    Free relief database
    Feb 2012
    74
    Oct 2010
    69
    With 2.62.
    Now I try to find better way for make smooter 3Dmodell from depth maps.
    This relief maded with usual process. (locally hand smoothed)
    Thank you Aues!!!
    KisKZ
    HobbyCnCArt
    Feb 2012
    74
    New
    Soon a new video tutorials
    Oct 2010
    69
    Hello aues!
    Those who have already purchased it will go?
    Have a nice day!
    Feb 2012
    74
    Hello aues!
    Have a nice day!
    Yes!
    Creation of bas-relief from 3d - Advanced (more 15 video lessons, examples and mega-bonus!)
    Oct 2010
    69
    We are catch 300th free relief on HobbyCnCArt
    Aues!
    Thank you for your help in this!
Page 1 of 2 12
  1. Share 3D relief (File GreyScan) free!
    By VietNamese in forum Vectric
    Last Post: 02-25-2018, 02:56 PM
  2. ArtCAM Insignia Halloween Demo With Free Relief Models
    By Chrisartcam in forum News Announcements
    Last Post: 10-30-2012, 05:54 PM
  3. NEW FREE 3D BAS RELIEF!!!
    By quazga in forum News Announcements
    Last Post: 04-02-2012, 04:38 AM
  4. Online ArtCAM Demo & Free Relief Models
    By Chrisartcam in forum Uncategorised CAM Discussion
    Last Post: 11-30-2011, 06:03 PM
  5. Free Relief Models from 2Dto3D Studio
    By 2Dto3D Studio in forum ArtCam Pro
    Last Post: 04-28-2010, 06:25 AM
