single block is a mechanical toggle switch. In normal auto operation it should be off. it can't be turned on by the machine. it is a manual switch.
regardless the machine should not stop after each line if single block is off.
is this the same machine where you have not fully loaded the PMC and other parameters?
if yes you really can't expect it to work properly until all the parameters are put back in.
