588,588 active members*
13,265 visitors online*
Page 3 of 3 123
Results 41 to 60 of 60
  1. #41
    Jun 2009
    43
    Yes, I got it set to read the same as my DRO's. I went into config, ports and pins, MPG, and set the units to 4.00. This made each mark of my mpg read as .0010". So equally one turn around is .1000". As far as the Ajax setup, so far I like it and it has a lot of future expansion options. Now that more and more people are getting them there is starting to be a lot of information out there in message boards. So if you run into some problems (and you will just because every machine is different) just do a search here or at the Ajax support forum. Scott
  2. #42
    Feb 2007
    664
    Quote Originally Posted by cncsnw View Post
    Do you have the T-shaped pendant with a plastic housing, a rectangular pendant with a metal housing; or no pendant at all?
    With the T-shaped pendant, you can only use a Centroid MPG, because the pendant expects to communicate with an MPG that contains its own Centroid processor.
    With the newer rectangular pendant, you need a sufficiently recent version that it has a header on the jog panel board inside for the newer "dumb" MPG's: those which just output selector switch contacts and handwheel pulses without trying to process them themselves.
    If you have a rectangular pendant and are not sure what MPG it supports, remove the face plate (4 screws) and post a good photo of the board you find on the back side.
    If you have no jog pendant at all, you will need to buy one of those first. The MPG handwheel pendant connects to the jog panel board; not directly to the CPU7.
    can i put a diy dumb mpg on this jog pendant ?
    and if i can, what would be the pinout ?
  3. #43
    Feb 2008
    280
    What does the rest of the PIC chip label (hidden behind the wires) say?
  4. #44
    Feb 2007
    664
    thanks for the help
  5. #45
    Jun 2009
    43
    Wow, its hard to belive it been almost two years since I was involved in this thread. As I read back through, it almost sounds Greek to me. The mpg 2 is still working good and so is the dc310b. And mpu 11. I use them a lot and i have not had any problems. Every once and a while the mpg will run out .0005" instead of going to .0000" where I started. But i have learned not to sweat a half a thousandth. All is good and i hope this thread will help others as it did me. Scott
  6. #46
    Feb 2007
    198
    Quote Originally Posted by rppman View Post
    That is good to hear Scott.
    Are you running Mach or CNC11? How do you like whichever one you are running?
    What machine are you running this setup on?
    I am just getting my hardware hooked up now. Have the servos running, and I need to decide on what software to run.
    Thanks,
    Scott
  7. #47
    Jun 2009
    43
    I am using mach3 on a gmc 10 x 54 knee mill. I noticed on one of the adds about the wireless mpg . Looks pretty cool but i don't know if it would work with the ajax plugin.
  8. #48
    Feb 2007
    664
    Quote Originally Posted by holbieone View Post
    thanks for the help
    Bump
  9. #49
    Feb 2008
    280
    Yes, you should be able to connect a third-party MPG to that header.
    There will be pins for +5VDC and 0VDC; axis select switch positions 1-5; increment select switch positions x1, x10 and x100; and encoder channels A and B. It is designed for a single-ended (TTL) pulse generator.
    Unfortunately, none of the documents I have show the pin assignments for the MPG header. That information will have to come from Ajax or Centroid.
  10. #50
    Jun 2004
    36
    Please see attached document for MPG pin assignments.
    Attached Files Attached Files
  11. #51
    Feb 2008
    280
    (Disregard)
  12. #52
    Feb 2007
    664
    cncsnw , AjaxCNC
    thanks for the help , i have the mpg wired up and working
    thanks again
    Kevin
  13. #53
    Jan 2008
    43
    Question Centroid puzzlement
    greetings Marc or Keith
    here are pics of two Centroid? boards and membrane. they snap together. any idea what control they are compatible with?
    thanks
    jackson
    ps-thanks Marc for the great help you provided Shamus on the Aciera F5.
    https://picasaweb.google.com/pulsenpal/CENTROID
  14. #54
    Feb 2008
    280
    Picasa says "Sorry, that page was not found".
    It sounds like you may be describing a jog panel assembly. What are the names on the circuit boards?
  15. #55
    Jan 2008
    43
    sorry Marc
    security setting altered
    jh
  16. #56
    Feb 2008
    280
    They are jog panel parts for mixed controls.
    It would be a complete set for a 1996-2002 M400 or M39, except that the keypad (dome pad) board is populated for the earlier M10/M40 family jog panel.
    Note, for example, you if you lay the overlays on the dome board, there is no key under the Z- jog button. Also, I think the M39/M400 dome boards had rounded corners, with no mounting holes.
    See Field Guide to Centroid Controls, 1994-2010 - CNC Services Northwest for an explanation of the different control models.
  17. #57
    Jan 2008
    43
    thanks
    thanks Marc for info. Yes, I noticed no blister domes under some labeled blister buttons. I actually lifted the sticky and moved a few of these to correspond with button functions. Not sure if this will result in anything good happening.
    anyhoo, I did notice CNC 7 on board. I have a Romi lathe with CNC 7 but this board assembly is for mill. So, back on the shelf.
    jackson
  18. #58
    Feb 2008
    280
    There is no difference between a lathe jog panel and a mill jog panel, except the printing on the overlay.
    On a lathe overlay the first axis buttons (left and right) are labeled "Z", and the second axis buttons (up and down in the center) are labeled "X". Different overlays are available depending on whether you want X+ pointing up (tools in the back) or down (tools in the front).
    If you want a lathe-style overlay, I can supply one for $56.
  19. #59
    Jan 2008
    43
    mpu 11
    Marc
    I have an MPU 11 kit I plan on installing on a Deckel FP4A this summer. Will this pendant from cnc 7 work with the MPU 11?
    jh
  20. #60
    Feb 2008
    280
    No.
    MPU11 systems use different jog panel communication protocols, and therefore require different firmware on the jog panel processor board.
Page 3 of 3 123
  1. SX15 control vs. Dx32 control
    By DF-ENTERPRISES in forum Bridgeport / Hardinge Mills
    Last Post: 04-12-2009, 07:44 PM
  2. Seig x2 Speed Control and c6 Control Board
    By skmetal7 in forum Benchtop Machines
    Last Post: 04-21-2008, 09:17 PM
  3. Replies: 2
    Last Post: 12-28-2007, 04:57 PM
  4. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
  5. BobCADCAM Layer Control / Snap Control
    By jonbanquer in forum BobCad-Cam
    Last Post: 01-21-2006, 10:10 PM
