588,205 active members*
4,119 visitors online*
Results 1 to 10 of 10
    May 2011
    212
    Wiring two e-stops
    I want to use two e-stop switches on my machine.
    I've got one on the enclosure wired up to the Gecko 540 as suggested by the mfr. working perfectly. However I want another switch where I usally observe the cutting, how do I wire this second switch? I have tried "inline", but then neither work.
    Ideas?
    Mar 2010
    371
    Is your existing e-stop normally closed (zero ohms when in "operate" position)? That is the normal condition. If it is, then you wire them in series.
    If it is normally open (infinite ohms when in "operate", zero ohms when in "Stop"), then you wire them in parallel.
    Dec 2003
    24220
    It almost sounds like you may have the original N.C. and maybe have add a N.O. in series, or do you mean when you push either one you do not get an E-Stop?
    Al.
    Albert E.
    Apr 2005
    253
    wire your emo's in series, use normally closed, N/C switches
    I'll get it finished sometime after I start it.....
    May 2011
    212
    Hm, both my switches are normally closed, why it didn't work when I wired them up earlier is beyond me. I'll have to try again.
    Let me wire them up and post a photo for you guys to look at. Electronics is not my strongest field.
    Thanks for now.
    Dec 2003
    24220
    Were they both maintained stop/twist release or is the new one momentary?
    Al.
    Albert E.
    May 2011
    212
    (chair) First of all, thank you very much for your quick replys. Second, I'm sorry to waste your time. Turned out to be a stupid wiring mistake, was sorted in 2 minutes after getting my head around what I had f'ed up
    Oct 2008
    406
    Quote Originally Posted by henrikm View Post
    Don't be too hard on yourself. Anyone who claims never to have made an oops like that is probably telling a tall one.
    Bob
    "Bad decisions make good stories."
    Nov 2009
    4415
    No magic smoke came out, you didnt do anything wrong! Welcome to the club.
    Nov 2007
    483
    Quote Originally Posted by Fastest1 View Post
    If it makes you feel any better in the last 2 weeks I've "magic smoked" a case fan and a solid state relay. I've gotten into the habit of ordering two of everything.
  1. MX40HA stops at seq. 10, ATC.
    By Roy Clegg in forum Okuma
    Last Post: 09-10-2011, 12:59 AM
  2. Please Help! cut stops on ar 400 plate
    By GraemeAMH in forum Torchmate
    Last Post: 07-14-2011, 03:50 AM
  3. X stops moving.
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 12-16-2010, 06:29 PM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
  5. Crusader just stops
    By harvard5 in forum DNC Problems and Solutions
    Last Post: 09-20-2005, 02:19 PM
