Originally Posted by
partsman
I am getting conflicting info on my VF-2 spindle type. The seller says it is absolutely a BT40 but there is a sticker on the machine that looks to me like it says CT40 or DIN/ISO.
Is there a way to know for sure? I dont want to use the wrong holders.
That sticker is on all machines. It just gives the dimensions on the pull-studs, with the only difference being the threads.
Also, both tools will fit the spindle, the difference is in the location and such of the fingers in the tool changer, as the location is different on the tool holders. CAT40(Caterpillar designed I believe) is the most common used. BT40, metric, is the European standard.
Both work the same, but you may find more tooling for the CAT40 machines.
Mike
The spindles are identical from what I know.
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
