588,336 active members*
4,383 visitors online*
Page 21 of 72 1119202122233171
Results 401 to 420 of 1431
  1. #401
    Here's a little video showing I could easily get 10 inches on the X now with the remote extruders
    anymore and the glass bed would hit the frame and also the fume extractor.
    Hoss
    [ame=http://www.youtube.com/watch?v=mWGg9WqHq5U&list=UUjoRKEpk7uE5Wzf4b-IFTFg&index=1&feature=plcp]Reprap Prusa Extra Travel. - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails 101_0087_cropped_751x600.jpg   101_0089_800x600.jpg   101_0092_800x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #402
    For the ABS fume extractor, I made the filter and filter lid from this thingiverse thing
    Simple Fume Extractor for ToM with 80mm Fan and Carbon Filter by scootnfast - Thingiverse
    and this 80mm fan bracket
    Quick and Easy Fan Holder (80mm) by Stu_Dkn - Thingiverse
    As you would guess it uses a standard 80mm pc 12v fan.
    I ordered some charcoal air filter from Mcmaster.com #20695K61
    This is the power cord support for the plug outlet in the rear.
    Power Cord Support by foxdewayne - Thingiverse
    This is for the power switch support, I made the blank one.
    Power switch support by fdavies - Thingiverse
    Hoss
  3. #403
    Nov 2009
    4415
    Suck the fumes up and out to where? Just put it in the bathroom with the fart fan on!
    Btw, that switch link on thingiverse from an fdavies, I bet that is the Frank?Davies from the Houston Hackerspace. He built an encoder cover for a robotic arm (this was the first time I ever saw a hobby printer do anything in person.) Small World
  4. #404
    The charcoal filter is supposed to take care of the odor.
    Not a problem for the other, they smell like roses.
    Hoss
  5. #405
    Nov 2009
    4415
    Only to you I am sure!
  6. #406
    Oct 2010
    266
    have you messed with skeinforge?
    i have python installed but skeinforge wont run. just pops up a command prompt that very quickly goes away
  7. #407
    Nov 2009
    4415
    Jeremy, give it a while. IIRC it takes A minute to load.
    A lazy man does it twice.
  8. #408
    Oct 2008
    1645
    Hoss,
    You have really shown the capabilities of these 3D printers and seem to make it easy for anyone wanting to get into the hobby. I however am busy with the metal working portion and so I'm selling my fully assembled H1.
    I just don't have time to mess with it now days with all my other commitments. If you or any of your fellow followers are interested in it they can contact me via PM.
    I know you already have two or three of these printers in progress but I didn't figure there was any sense in mine collecting dust.
    Richard
  9. #409
    I might sell my kit still in the box too, don't see any point in going down that road now.
    Mach 3 was the attraction in buying it but of course one doesn't need the other,
    mach can be set up to run a prusa and ramps could run an H1.
    Like most others have said, a bigger second printer made from aluminum/linear rails/ 80/20 or whatnot more
    like a router would be better time spent.
    I'm hotrodding the prusa a bit and it will be a great little printer that will get lots of use as time goes.
    Now that I've got the RAMPS figured out and see how much it can do in such a small package
    I don't see any benefit in trying to use Mach 3 as the control unless I build something that needs nema 23 motors
    and my bigger drivers.
    Working on a few more pimps for the prusa first though.
    Hoss
  10. #410
    Nov 2008
    24
    Possible hardware issue
    FWIW, watch out for poor fitting hardware:
    [ame=http://www.youtube.com/watch?v=4y8GFYylLlM&feature=related]Prusa Z rod and nuts eroded. - YouTube[/ame]
    thanks,
    -George
  11. #411
    Quote Originally Posted by hgk View Post
    thanks,
    -George
    Sorry to say but they need to learn how to lube their machine.
    A daily squirt of oil will do wonders.
    The z rods aren't exactly breaking any speed records, they make one slow
    climb per print.
    Still, I guess we'll have to look at a ballscrew upgrade.
    Hoss
  12. #412
    Jun 2004
    6618
    It appears to be the nuts that stripped.
    You can get better quality nuts to help with that. That and lubrication like Hoss mentioned are key on these I think. I also use a spring in mine. I lube with light weight 3in1 machine oil.
    Seems to do well, but I only have about 24 hours of printing under the belt so far.
    Lee
  13. #413
    Nov 2009
    4415
    After watching that generally I would be conerned. However after owning a Sherline with 1/4-20 screws that ran via CNC just fine, lube would do wonders. A little bit of backlash is to be expected but you can definitely keep it to a minimum.
  14. #414
    I used springs in the z axis too which act just like a double ballnut setup to eliminate backlash
    but I keep the spring force reasonable so wear isn't accelerated.
    We'll see in 9 months.
    Hoss
  15. #415
    Mar 2005
    335
    I am sorry but that is obviously the wrong nut for the threaded rod.
    could be M8 on 1/4 or something else.
  16. #416
    That was my first thought but he claims it wore out after 9 months in his video comments.
    Also it is a video by scribblej who comes up with some cool stuff in the 3D printer world
    but may not have been much on machine maintenance as the threads look pretty dry.
    Hoss
  17. #417
    Oct 2010
    266
    oh man that sucks, gonna cost like a few bucks to fix that, ouch.
  18. #418
    Nov 2009
    4415
    Some all thread and or a few nuts, that is going to cost some bucks? Never mind I was too stupid to catch the sarcasm.
  19. #419
    Oct 2010
    266
    damn it, now this 3d printer stuff has got me into looking at arduinos and all the cool stuff you can do with them. now i want to buy one and other electronics and learn how to do fun things with them!!!!!!!!!!!
    i need to stay off the internet :boxing:
  20. #420
    Oct 2008
    1645
    How well did your Mark IV hot end fit your Gregg's extruder. Mine is loose as a goose. It fits my Wades extruder nice and snug.
    I guess I will have to wrap it with some tape or something. I am not impressed with the print quality of the one I just got today. Some of my first prints looks better than what showed up today.
    I sure hope your is better.
    Richard
    Quote Originally Posted by LeeWay View Post
    And some guys never have any trouble with the Wade's.
    I haven't heard of anyone that has had trouble with the Greg's.
    I just got mine yesterday and will be installing it very soon.
  1. mhackney's 3D Printers
    By mhackney in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-04-2014, 09:17 AM
  2. ROBO 3D Printers
    By CNC_Kid in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-13-2014, 09:13 PM
  3. Why have 3D printers in the classroom?
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-23-2013, 04:10 AM
  4. 3D Printers why so quite on here?
    By xairflyer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-17-2012, 04:55 AM
