587,161 active members*
3,366 visitors online*
Results 1 to 7 of 7
    Dec 2007
    341
    Smile Re vfd settings
    Any on know the frequency settings for the 1100, low and high output for the new vfd. with the 1.5 hp motor
    Jun 2006
    2512
    5.8 to 143.1
    Phil
    Quote Originally Posted by woffler View Post
    Dec 2007
    341
    Wink
    Thank's Phil
    Jun 2010
    Hi Phil and Woffler, do you have the correct Paramaters for the VFD (series2 commander sk)?
    If it's not to much of a pain can you please post them below - I'm having issues with the parameters on my one and I want to check them against a working set.
    Thanks guys it would be mighty appeciated..
    Jun 2006
    2512
    There appears to be as many as 80 user defined parameters and I currently don't know how to read them. If you want me to take the trouble to find out how to read them, note them down and then type them into an email you will need to be much more explicit as to which ones you actually need.
    I am happy to read off the odd couple of parameters to enable you to solve a specific problem. However, with all due respect to Tormach, I would not be happy to read off the whole list of parameters.
    Phil
    Feb 2007
    1041
    I own a series II and here's what my VFD reads in the high belt setting
    250 rpms - *Fr 6.6
    3100 rpm - *Fr 89.0
    5140 rpm - *Fr 144.4/144.5*
    Dec 2007
    341
    Could you give us a hint as to what the problem is so we can narrow it down and help you solve the setting problem. As Phil said there are way to many settings and ours may differ from yours and you particular machine.
  1. DSP settings
    By rocabig in forum Excitech routers
    Last Post: 07-14-2016, 07:40 PM
  2. Settings Help...
    By JHBarber in forum Haas Mills
    Last Post: 12-15-2010, 06:35 PM
  3. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  4. LOOKING FOR SETTINGS
    By curlyweld in forum Waterjet General Topics
    Last Post: 03-20-2008, 07:14 PM
  5. dnc settings
    By jamesr in forum Fanuc
    Last Post: 02-02-2006, 09:13 PM
