588,423 active members*
5,498 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How can MC cut this part?
Results 1 to 16 of 16
    Feb 2005
    234
    This is just cutaway part, it's cylinder.
    Can Mc cut this?
    How ?
    C
    Dec 2008
    717
    Mastercam can be programmed for a mill or lathe to cut that part but my mastercam doesn't actually cut parts - my mills and lathes do.
    Seriously, though. Lathe part. Done...or use a saw on a mill(wedge)
    Tim
    May 2004
    4519
    If you do not know how to make the part on a manual machine, using MasterCam will not help you make it on a CNC machine.
    Feb 2005
    234
    I've been cutting parts using cnc router with mach3.
    Toolpath created with rhinocam so far.
    Can i use MC to cut this "pocket" part ?
    I meant to create toolpath, not to cut.
    that's the word, sorry ....
    I don't think rhinocam can cut this part.
    The part above is a cutaway section, so it's a cylinder part with pocket.
    C
    May 2004
    4519
    What tool do you plan to use for machining?
    Feb 2005
    234
    Quote Originally Posted by txcncman View Post
    I will use lollipop mill bit or tslot bit.
    It's up to the program actually.
    Dec 2008
    3142
    Quote Originally Posted by Calico View Post
    Ha Ha Ha Ha Ha Ha .... :banana:just love that last line !!!
    - Drill
    - interpolate the smaller bore diameter to get a flat bottom, and straight wall
    - Tee slot cutter working from the flat bottom stepping up to wards the top, make sure swarf is evacuated whilst cutting
    Feb 2005
    234
    Quote Originally Posted by Superman View Post
    - Drill
    Thanks, tslot cutter.
    Gotta check
    May 2004
    4519
    This is why I do not go too far out of my way to answer these kinds of questions. You got to have a clue of some basics before you can understand the answer.
    Dec 2008
    717
    He's actually very close to being correct....just two little letters
    Should have read:
    It's up to the programer actually.
    (nuts)
    Tim
    Feb 2005
    234
    Yeah... Make fun of my 2nd language........
    Thanks for your help
    Dec 2008
    717
    Personally, I wasn't making fun of your language...
    But if you meant Program or Programmer...those are 2 entirely different things. I assume you did mean program as you are the programmer...which in this case gave us a chuckle.
    Tx has a valid point in that many come here and don't have the first clue as to the basics so often times help falls on deaf ears.
    I think we answered your question though.:wee:
    Tim
    Aug 2011
    2517
    if its an enclosed cylinder it'll be very difficult to machine by a noob because access to the inner cavity is only available via the front hole. that kind of thing is better fabricated from separate pieces, welded then machined on the external faces and large hole to true it up. alternatively its a pretty easy lathe turning/boring job but finding an internal grooving tool to machine the square shoulder to depth might be an issue. it depends entirely on what it does and what goes inside it.....
    Feb 2005
    234
    Quote Originally Posted by fordav11 View Post
    Actually it is not a cylinder that I'm working on.
    Can not use lathe because of the shape.
    What I need to know is how MC can do this inner hole mill.
    I can not find any sample tutorial on video or web to get me the idea.
    I have not got time to try the "helix" cut yet, just what expert here suggest me.
    May 2004
    4519
    This is about as simple as I can make it for you:
    Attached Files Attached Files
    Feb 2005
    234
    That's more than "simple" to me, appriciate that.
    Thank you
  1. I need a very “small part” part catcher
    By Vern Smith in forum Haas Lathes
    Last Post: 08-25-2010, 01:55 AM
  2. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
  3. sheetmetal part? flatten a rolled part?
    By Rich05 in forum Solidworks
    Last Post: 08-13-2009, 04:22 AM
  4. Verify Cut part to Design part.
    By CaseyCAM in forum NCPlot G-Code editor / backplotter
    Last Post: 11-02-2008, 03:22 AM
  5. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
