588,532 active members*
8,317 visitors online*
Results 1 to 13 of 13
    New VF-2 SS Glitch ??
    I've got a newer (10/2011) VF-2 SS that seems to have a software bug. Running Software V18.05 I believe.. I'm at home right now, so don't have it right in front of me. When you stop a running program, then jog the Z up, once in a while it will move in the X or Y about 1/2" or so before moving up in Z. It has done it enough times for me to know I am not crazy. The first couple of times I wasn't sure
    Just something to keep a look out for out there. It has not caused any problems for me, because luckily every time it has happened the tool was above the part.
    May 2004
    4519
    Do you actually mean "jog" as in manual jog mode? Or do you mean rapid Z+ in a program? Would like to see the program. Would also be cool to see a video of the machine movement as well as the DRO of the machine when this happens.
    Quote Originally Posted by txcncman View Post
    As I said, when you stop a running program...... Then Jog up up the Z axis, which would be handle jog.... It has nothing to do with a program as it has done it to myself and other guys in the shop as well on while working on different jobs on that machine. It will not repeat.. It has randomly done it maybe 4 or 5 times over the last 6 months.
    I have 9 Haas mills, the first one I bought new in 1994. I'm a little familiar with how they operate. I also have a former Haas Tech working in my shop, who is still factory certified, that say's it's a software issue. This particular machine is only 6 months old, and already had to have the software updated because of some issue with the alter button. Now it's a different bug. I hope they get it figured out because I have another mill on order right now.
    Mar 2010
    1852
    As a test, I would write a simple program that has moves in +X, -X, -Y and +Y and try stopping the program in each direction and then seeing if the machine messes up the +Z in jog. It almost seems that it is staying in the previous axis movement for a brief time. Since most of the time programs are stopped in a Z+ move, it would not show up often.
    I certainly see where that issue can cause some big problems with damaged parts and broken tools.
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    May 2004
    4519
    Quote Originally Posted by CaboWaboKJB View Post
    As I am about to say, I had no clue how much experience you might have. I had no clue how many in your crew had this experience. That is one reason to ask questions. Asking questions was not intended to make you look stupid. Asking questions was to clarify information, to make sure that communication was going well. I would be surprised if Haas did not or does not ask you the same questions. I will keep any other comments on his subject to myself so as not to further offend your extreme experience and intelligence.
    Apr 2009
    17
    I have this happen to me all the time on DT1s, brand new. I notice it happens when I go from memory to handle, then change axis. I will get the XY or Z to do the random move not just Z. I think my fingers are too fast....
    Apr 2009
    17
    Just to add more, now that I am thinking about it, I think it has to do with the whole new setup key crap.
    Feb 2010
    1184
    Call your dealer and explain the problem to them. See if they will do a software upgrade to alleviate the problem. If that doesn't work, maybe they can get the factory involved to come up with a solution.
    Good luck!
    Jan 2008
    575
    txcncman;
    Do you have ANY experience with Haas, at all? Do you own a Haas? Have you worked with a Haas? Have you seen a Haas? Answering questions with questions is like throwing straw at fire. Completely counter-productive. From what I have read, that is all you post.
    Regards, Robert
    The beaten path, is exclusively for beaten men.
    May 2004
    4519
    Quote Originally Posted by littlerob View Post
    txcncman;
    Regards, Robert
    Yes.
    No.
    Yes.
    Yes.
    Feb 2010
    I have the same issue on my 2011 DT1. The only fix for it that I have found it that you need to slow down, and hit the button twice for the axis you want to jog. Now my 2010 VM2 does not do this. I have only snapped 2 tools off. Tech that was in for the leaking coolant had no idea regarding the issue.
    I was going through old threads and came back across this one. Just to follow up, the problem was fixed with a software update to the machine. All is well.
    Mar 2007
    23
    I can confirm this issue. It has been happening every now and then with both of our (2010 and 2012) VF3-SS machines. Its kind of scary when you work in a hurry.
    I have destroyed couple indicator tips because of this (trying to jog Z+ after finding the part edge in X or Y)...
  1. Enroute Pro 4.1 posting glitch?
    By Leesrt in forum EnRoute
    Last Post: 12-17-2010, 02:20 PM
  2. Polyline Add Possible Glitch 2010
    By Lafaso870 in forum Jewelry Design Software
    Last Post: 11-19-2010, 09:11 AM
  3. POST Glitch
    By bmlw in forum FeatureCAM CAD/CAM
    Last Post: 05-21-2009, 07:21 PM
  4. Centroid M400 Glitch
    By rdoty in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2008, 08:18 PM
  5. VMC ATC Glitch?
    By One of Many in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2007, 12:58 AM
