587,753 active members*
2,992 visitors online*
Page 3 of 5 12345
Results 41 to 60 of 84
  1. #41
    Feb 2009
    116
    Nice!
    I would love to add this to my FLA-100 setup!
    I look forward to more info!
    -CNC74-
    CNCART.NET Welcomes you!
  2. #42
    Dec 2009
    19
    This is a router, just as you described, it's just being used in a different way.
    DPRouter 4'x8'x8", Rockcliff Driver, 425oz. Nema23, 2HP, Belt drive xy, Acme z,
    400ipm rapids, 120ipm safe cut
  3. #43
    Dec 2006
    177
    Might I ask what the costs were in adding this to your CNC router?
    When I looked into the costs it was starting to get up around the $300 mark for all the parts and then I would have to manually edit the gcode to work correctly with Mach3.
    I have since then purchased the $300 MakiBox, still has not arrived yet but it is a complete 3D printer. So I will not have to change out anything on my CNC router and I can run both machines at the same time on separate projects, this is only my opinion and the way I choose to work ohterwise I would have made my router into a multi use machine also.
    Tom
  4. #44
    Dec 2004
    1137
    Just one comment. I can't think of any case where you would need or want to mill a printed part. That's the beauty of reprap, you print what you need including any bores, countersinks, etc. Furthermore, most prints are a percentage fill, so drilling/milling anything other than a solid will weaken the structure.
  5. #45
    Oct 2010
    65
    Quote Originally Posted by DeadTom View Post
    Tom
    I just finished building an extruder for my cnc router, I made almost everything on the extruder myself, loosely based from this design, cost was approx $70,:banana: but as you mention, it would have been higher if I had to buy every single part,
    I also looked into the makibox, but could not part with the money even at the low price of $300, it was tempting, but I personally felt it too much of a risk to buy something that was not a real product and still experimental, plus I wanted something right away, and my cnc router was already built, so adding the extruder, was just too easy,
    No editing on the gcode, 3D STL + Kisslicer + Mach3 + Cycle Start = Printed Part
  6. #46
    Dec 2006
    177
    Yeah, I have had my doubts and reservations with parting with $350 but I did not have the time to commit to buying and building all the needed parts for a conversion. And I did not mind waiting for this MakiBox also I am currently building another CNC router all welded steel and higher end parts (no flex). I do like what the others have been doing on this thread though, all good stuff.
    Tom
  7. #47
    Dec 2010
    634
    Quote Originally Posted by Jay C View Post
    Just because you can't think of it doesn't mean it doesn't exist.
    BTW, not knowing much about how solid these structures are but, my router has a work envelope of about 19"x28". How big is the table on a rep rap?
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  8. #48
    Jan 2008
    853
    Would the precision of the machined surface be superior to the raw extruded plastic? If so, the combination would be quite useful.
  9. #49
    Dec 2004
    1137
    Quote Originally Posted by BanduraMaker View Post
    The envelope is 210mm X 210mm, by ~120mm on a Prusa Mendel.
    And don't get me wrong, adding a print head on your CNC router is great, but thinking you'll need/want to mill it afterwards makes no sense is all.
  10. #50
    Oct 2010
    65
    My wife says the same thing, "it makes no sense" with everything I do
    but I do it anyway (flame2)
  11. #51
    Dec 2010
    634
    You're just lacking imagination :stick poke
    If you can envision a feature that requires resolution finer than one can achieve with an extrusion type 3D printer, you can envision a reason to machine a printed part.
    -Andy B.
  12. #52
    Dec 2009
    19
    With all due respect Jay, I disagree. Think beyond printing plastic parts.
    Having more than one process at your disposal opens many doors. Maybe you would want to mill traces into a PCB and then print plastic over a certain area to seal it off... That's just one idea outside of 3D printing, I'm sure folks besides us can think of many more.
    Ever tried adding small engraving to a part on your 3D printer? The results are less than spectacular - unless of course you print the part and then come back and engrave with the mill. I even want to try to mill a mold or 3D pattern and then print plastic over it to make a part. It would take a bit of tricky programming on the gcode side but that's okay. Better yet, mill a small mold, close it up and use the extruder to "inject" plastic into the mold - there's a whole industry centered around "micro molding", maybe they need prototypes?
    I hope I can sway you to the "dark side" Jay C - you seem very knowledgeable on this subject.
  13. #53
    Dec 2004
    1137
    Quote Originally Posted by darrinp View Post
    I own a CNC router too. It hasn't seen much use since I built my first Mendel. Once you start printing, you'll "get it", and understand where I'm coming from. Have a look: [ame=http://www.youtube.com/watch?v=dKw9d8cF1hk]Reprap Prusa G0704 Z Axis Stepper Mount - YouTube[/ame] The intent is not to add more post-processing, it's to print it in one go.
    I'm not trying to discourage you, just one man's opinion based on personal experience.
    -Jay
  14. #54
    Oct 2010
    65
    I guess it really depends on what you perceive as finished, if the part is good enough for you straight from printing, that's great, I personally like things better, see the whole video, but skip to around 8:30 for accuracy of printed parts
    [ame=http://www.youtube.com/watch?v=q7rMG5aWEY0&t=8m40s]Reprap Prusa Printed TTS Toolholder Test 1 - YouTube[/ame][/URL]
  15. #55
    Feb 2009
    1290
    I might be a little confused here but what I'm thinking is using the extruder to do something like an inlay on a wooden or acrylic sign. If using the glow in the dark plastic as lettering, it might turn out cool.
    V-Carve the sign the fill the carved sections with plastic, if it will stick.
    Thank You.
  16. #56
    Dec 2010
    634
    I think the more folks think on it, the more creative possibilities of combining the two folks will dream up.
    -Andy B.
  17. #57
    Dec 2004
    1137
    Quote Originally Posted by Drools View Post
    It won't by itself. But you could print then epoxy it.
  18. #58
    Dec 2004
    1137
    Quote Originally Posted by Markwind View Post
    Just curious how one might post-process this part to make it "better" FDM has it's own set of challenges mostly around the heating and cooling properties of the print material. He has another video showing him cutting aluminum with a printed TTS holder too.
  19. #59
    Oct 2010
    65
    I believe in the video of the TTS holder he cut aluminum, the holder was machined true after it was printed,
  20. #60
    Dec 2004
    1137
    I think you are right. He talked about using a lathe to remove a chamfer he had to add for overhangs, probably to true the mount stem, and he used a reamer or boring bar for the hole. Neither of which was done in situ so my opinion is not changed on that. And I admit I have had to ream/drill holes, sand, and cut stringers after a print so there is post print clean up.
    What he didn't do was mill it, though based on the first video and a 6-hour print time, looks like he printed it solid so he could have. But, what you'll learn as you experiment is that you want the print to stick so the part stays flat, but not too much to where it won't release with some help from a putty knife or hand pressure. Otherwise, you will be less inclined to use it due to the extra post processing effort. In the example video he glued the printed ABS part onto ABS using acetone on the ABS plate before printing. That holds it great for milling, but how you you get your part off
    The best part about the approach shown is that the print head is on the backside of the router and thus out of the way and not requiring any swapping to do one or the other.
    FWIW,
    Jay
Page 3 of 5 12345
  1. Building a cnc router with an old printer and an old scanner
    By codemaster in forum Open Source CNC Machine Designs
    Last Post: 09-16-2013, 03:10 AM
  2. router/3d printer 1x0.7x0.3meter modular design
    By watanabe in forum DIY CNC Router Table Machines
    Last Post: 06-05-2011, 03:58 AM
  3. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  4. Converting a CNC router into a flatbed printer
    By d_chappell in forum DIY CNC Router Table Machines
    Last Post: 01-11-2010, 06:10 AM
  5. Printer for PCB ?
    By WayneHill in forum CNC Machine Related Electronics
    Last Post: 10-05-2005, 06:42 AM
