588,548 active members*
5,162 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Way to tie Pcool height to tool length?
Results 1 to 13 of 13
    Aug 2006
    69
    Seems to be a fairly logical thing to do, have the pcool height be referenced to the tool length, especially for those of us with probing.. I find it annoying that I have to manually set pcool for each job, when the machine already knows the tool length.. Am I missing something?
    May 2004
    4519
    It is logical up to the point until additional logic kicks in and you realize that you do not always want the coolant stream to be aimed directly at the tool tip. So, if you do figure out a way to do this, be sure to incorporate a way to turn the function on and off.
    Oct 2009
    7
    Be pretty easy to implement if you feel so inclined. Just have to figure out angle delta between each coolant position and then do the geometry. You could make it part of your tool probing routine.
    But as txcncman said there are plenty of cases where the coolant stream should not be pointed at the tip.
    Aug 2010
    579
    Haas Factory Support
    If you could incorporate the diameter as well for shell mills, you should be able to accommodate most situations.
    Here are the appropriate macro variables:
    #2001 - #2200 Tool Length
    #2401 - #2600 Tool Diameter
    #3201 - #3400 Actual Tool Diameter
    #3401 - #3600 PCool Position
    Thanks,
    Ken Foulks
    May 2005
    2502
    Tool diameter and top of workpiece seem like the two key things that together with tool length would let you at least get a programmable nozzle into the right neighborhood.
    Can the pcool nozzle be controlled via g-code?
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Aug 2010
    579
    M34 and M35 will command the pcool position.
    Thanks,
    Ken Foulks
    May 2004
    4519
    Thanks Ken.
    Jul 2005
    207
    Here is a macro that can be added to the Renishaw macros to set P- Cool.
    Credits go to user pit202...
    Code:
    O09880 ( spigot position calcutation )
    ( * author : [email protected]    * )
    ( * date   : 2009.05.04      * )
    ( * usage  : G65 P9880 Txx   * )
    #9= #[ 2000 + #20 ]
    #10= 66. ( min. tool length )
    #11= 8. ( spig. pos. for min. tool )
    #12= 185. ( max. tool length )
    #13= 15. ( spig. pos. for max. tool )
    #14= [ #13 - #11 ] / [ #12 - #10 ]
    #15= [ [ - #10 ] * [ #13 - #11 ] - [ #12 - #10 ] * [ - #11 ] ] / [ #12 - #10 ]
    #16= FIX[ #14 * #9 + #15 ]
    #[ 3400 + #20 ]= #16
    M99
    look at the first lines :
    Code:
    all you need to do is change those lines , find a shortest tool , messure it and find out which coolant position is the best, the tool length put in #10 value , and spigot position in #11 , do the same with a long tool , and put the values into #12 and #13.
    get a code from VQC to messure the tool , after G65 Pxxxx line put
    Code:
    G00 G90
    G65 P9023 A12. T1
    G65 P9880 T1       < ----- line added manually
    to not writing every time this line I added a line in the O9996 VQC file like this :
    Code:
    N1301
    (TEMPLATE)
    (NAME Auto Length Only)
    (GCODE)
    (T#ToolNo M06)
    (G00 G90)
    (G65 P9023 A12. T#ToolNo)
    (G65 P9880 T#ToolNo)             < ---- here is my line
    (M30)
    (END GCODE)
    Aug 2006
    69
    Sweet, thanks for the help guys!
    Apr 2010
    200
    The amount of thought and effort that goes into avoiding a little task is amazing sometimes.
    ...not that I don't do the exact same thing constantly.
    I set the coolant as the first part is run. I watch the approach of each tool anyways, so when I let the coolant go on I just enter the coolant offset as it begins its cut.
    Apparently I don't know anything, so please verify my suggestions with my wife.
    May 2004
    4519
    Quote Originally Posted by Pondo View Post
    +1
    Mar 2010
    1852
    +1 too!
    Also, just because you have a 3 inch long 1/2 inch endmill, there is a difference between a shallow cut on a piece of aluminum and pocketing out a piece of aluminum to 2 1/2 inches deep. So it is not always the same and are your operators going to assume all is good and walk away?
    Anyway, a fun exercise.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Jul 2005
    207
    I use it to get the p-cool in the ballpark. Then as I proof out the first part I fine tune it among other things.
  1. set up tool length offset and ref tool on mill
    By buklattt in forum CNC Machining Centers
    Last Post: 04-01-2012, 05:01 PM
  2. Tool Tip Length
    By eliot15 in forum MetalWork Discussion
    Last Post: 11-14-2010, 02:07 AM
  3. Tool Height Reference Tool
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 03-14-2009, 09:24 PM
  4. G43.1 - Tool Axis Direction Tool Length Compensatioin
    By EngTech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2007, 11:01 AM
