588,215 active members*
3,906 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Jan 2012
    broken tap in piece
    Man, I spent many hours making a part and then when I was tapping it manually, the tap broke with a lot stuck in and not a lot sticking out to unthread it.
    How do you remove taps?
    Heat it up then try unthread it?
    People have fancy methods like using EDM but I dont have that. The tap I believe is hardened carbon steel with titanium nitride coating. Presumably I can run a carbide end mill right down the center as its harder to cut it out. The problem also is the tap is super small. I dont think I have any carbide end mills that size, let alone that size to throw out.
    Any tricks?
    May 2012
    might try a left hand drill bit if its flat enough for the drill to bite
    Feb 2009
    95
    Saw a simple EDM arrangement for such cases somewhere on the net.
    Here's a link to a thread in another forum
    Home Made EDM
    Feb 2010
    371
    If the part is aluminum you can dissolve the tap by boiling the part in an alum solution.
    Feb 2009
    6028
    Tap out.
    You make a small dam of some putty around the tap, place tap out in the dam, after some period of time depending on tap size, the acid eats the tap away enough for it to fall right out.
    Here is one version of it
    http://www.chemical-supermarket.com/product.php?productid=574
    Apr 2006
    3206
    If the part is aluminum or stainless....
    Clean the hole and tap thoroughly.
    20% solution of nitric acid in tap water poured into hole with a clay (or suitable putty-like substance) as a dam and leave to soak. It could take a day or two....
    It'll bubble and smoke, and periodically you'll want to replenish the solution with fresh... and keep picking the pieces out with a dental pick or some such..
    If you have a low voltage power supply, hook up some aligator clips to the part and the tap to accelerate the process.
    ,,,,,,,,,,,, If you're patient and brave and have a carbide mill, you can mill it out. I've only managed to break the mill along with the tap.. so I don't do that. Some guys are really good at it. I ain't.
    Jan 2012
    The tool broke not with a flat surface. Yeah its a 6061 part. The tool is probably tool steel but TiN coated on the business end.
    I dont have any of those chemical methods right now and wanted quick solutions. So I broke a couple of tools trying a few things.
    Found a 1mm diameter carbide end mill. Plunge in is the only space I can do to fit in the space. Plunge in from the broken and not TiN coated end of tool. End mill broke right away.
    Put in a diamond coated grinding tool. Grinded for a while and it worked, but on deeper plunges in the cnc, tool started defecting around broken geometry and then broke.
    I then manually grinded the top flat with a ball nose diamond coated grinder. then tried to drill it in. Wouldnt budge since its similar material and hardness of course so backed off.
    All the while this has been probably work hardenining the tool more if its not already hard enough.
    I made a make shift approach to discharge machine it with a copper wire as the sinker. It worked but painfully slow. After a hour I can see a tiny hole eroded away, but at this rate it will take forever.
    I also broke another tap while trying to finish the other holes while figuring a solution to get the tap out.
    So now the part has 2 broken taps.
    Probably better to just remake the part and go real easy on the hole tapping where ill back off with the slightest resistance.
    Where do you guys buy the fluid for get rid of the taps? Theres a mechanical solution too like walton tap extractors (where 4, 3 or 2 pins are inserted into the gap depending on the design of tap to help unthread it), any tried them?
    May 2004
    4519
    I have had very poor luck with the fingered tap extractors. If you plan to break a lot of taps, look for a machine called a tap burner. Works similar to manual sinker EDM with a tungsten electrode, but no coolant. Alternative is to keep a lot of small 4 flute carbide end mills on hand. At least one for every tap you break. The most cost effective solution is to learn how to tap without breaking the tap. This is one of many skills that cannot really be described with words effectively. Even when demonstrated, it is a physical skill that has to be learned. Some people have some natural abilities to learn the "feel" of tapping. Many do not.
    Feb 2012
    In my experience of breaking of smaller taps in the bore I came to realise that its false economy and headbanging to buy cheap taps in the smaller range and is best to buy the best in these taps.
    some cheaper taps are very brittle material and are prone to snap in aluminium because of the nature of aluminium.
    Jan 2007
    175
    I normally use carbide ground into a spade style end, held in a collet , taking very small pecks at Max, Spindle speed
    Rockcliff Machine Inc.
    http://www.rockcliffmachine.com
    May 2010
    Where I work broken taps are a common occurrence.
    Through the years I have tried just about every method of removal.
    Sometimes peck drilling with a carbide end mill works but usually ends up chewing up the end mill by the time you reach the finished depth. I like to circle mill the taps out using a helical clockwise (Not Counter Clockwise) motion. It doesn't need to be much of an offset motion but best not to feed more than .005 per pass. High rpm plenty of flush coolant even a blast of air occasionally. Remember that the direction you fed the tap in there is not the direction you want to cut it out. Once the tap does decide to let go you don't want it screwing out and breaking your end mill. Good Luck !
    Jul 2010
    492
    Quote Originally Posted by bebob1 View Post
    Any tricks?
    if you are having issues tapping on a manual mill that used like r8 collets and such, a good trick is to leave it just a little bit loose so when it torques out, it spins in the collet instead of breaking the tap. then you can back out and tap back in like peck tapping.
    as for getting the tap out, usually we use a dull small carbide endmill since most sharpening companies wont touch anything under 3/8" due to replacement price. take it really slow with air blast and you can easily work it out.
    also, you might wanna look at a tapping fluid like anchor lube or tap magic or rapid tap. i highly reccommend anchor lube for stainless steels..
    Jan 2012
    Its hard to manual tap small holes where the tap tool cross section is so small. I can literally snap the taps with my bare hands if i wanted to. My tap was also really brittle. I think it failed because of material fatigue since I wasnt really putting too much force on it any different than the other operations.
    I bought another brand of tap and tried again, this one 2 flutes instead of 3 so cross section is larger. Its also HSS and not coated. Seems to be better as I now finished all the taps. I also changed the style of tapping, I rotate the tap maximum 120 degrees when hit with mild resistance when tapping, then I back off completely, clear chips in tool and hole and repeat. Small taps require more babysitting.
    Yeah, Im gonna throw another carbide at it and then I will give up. I will try the helical approach. The problem is, the end mills dont have enough reach and my threads go really deep. The tap is stuck deep. I think EDM is really the only approach but I dont have a commercial machine. DIY technique works but slow and now recirculating flow to flush dust away. This is quite important as it stains your part. Now my part has brown stains from the eroding of the steel tap.
    EDIT: I just got my hands on a 1/16" 4 flute TiAlN coated end mills. This stuff works. My other plain carbide 1mm broke. This one is eating it away, although I can only have enough space to do plunge milling. I lost one of the flutes that broke off but Ive managed to mill out quite a bit. although the threaded parts of the tap is still locked in.
    May 2004
    4519
    A final consideration in tapping is that machine tapping is way more consistent in the forces applied than hand tapping. While hand tapping, most breakage occurs, not from chip build up as falsely imagined, but side forces applied and tap alignment not being true to the drilled hole. Use a tapping jig or hand tap machine to reduce tap breakage.
    Jul 2004
    127
    So plain and simple, broken taps suck. I have yet to find a good way to remove small taps (4-40ish) that break below the surface. I usually just take some deep breaths, and remake the part. I've tried basically everything except for EDM and that nitric acid stuff. I haven't had much luck with drilling them out (using 140 deg carbide spade drill) or milling them out (although I haven't tried that too many times) I tried one of those finger tap removers and it didn't come close to working. Tried welding something to the tap- no dice.
    When I need to tap a 4-40 hole, I'll do the following. fyi I tap pretty much everything using a cordless drill on a low clutch setting. If I need to tap a lot of holes I'll use my tapping head.
    -use a larger drill bit (#41 in aluminum, sometimes even larger in steel depending on the depth). I generally will try to make the hole a through hole. Obviously you may not have these luxuries.
    -I use a high quality, 2 flute spiral point tap. FYI spiral flute taps break WAY more easily, and are just as difficult to remove when they break. If I'm doing a blind hole, I'll just drill a bit deeper, and the spiral point tap pushes the chips into the extra space.
    -use some sort of taping fluid.
    -I've also started to grind a groove in the body of the tap- the thought being that if I bend/over torque the tap, it will break there and not under the surface of the part. I haven't had to test this, but one day I came back and found that tap broken in half at the groove. I'd like to think I saved my brother some frustration.
    Hope this helps,
    -Matt
    Oct 2007
    269
    Quote Originally Posted by mcarvey View Post
    Hope this helps,
    -Matt
    Thanks for the tip. Great :idea: .
    Jim
    Dec 2006
    839
    Have you tried these before?
    JTS Machinery & Supply Co.
    Jess
    GOD Bless, and prayers for all.
    Feb 2012
    This is true.
    I had to appeal to my feminine side when tapping the other day,well you know what I mean multitasking anyway I put the tap in the benchdrill chuck lowered the chuck and twisted the chuck by hand,lowered chuck,twisted chuck,lowered,twisted till it was done,quite a task using both hands in that way.
    I can write me name with both hands at the same time so I quite pleased with the tapping the way it went.
    Jan 2012
    Be very careful with drilling oversize! Gages may work fine, but that doesn't mean you have an structurally sound thread. We've seen a couple cases of this over the years. The one I remember was like some #6 or #8 threads in 17-4 stainless. We had a light head fall in a medical facility. (I don't remember if it hit a patient/employee or anybody). After investigating, we traced it back to tapping issues which the operators "corrected" by drilling oversize. The GO/NOGO's worked fine. The threads didn't.
    Feb 2012
    I guess they musta felt light headed.
Page 1 of 2 12
  1. Piece by piece
    By cncadmin in forum EnRoute
    Last Post: 10-22-2011, 05:40 AM
  2. Broken piece
    By GTC in forum Syil Products
    Last Post: 10-18-2011, 05:21 PM
  3. What is this piece?
    By greenene in forum Mini Lathe
    Last Post: 09-01-2011, 11:53 PM
  4. my first 3D piece
    By 59caddy in forum Canadian Club House
    Last Post: 08-06-2009, 04:13 AM
  5. Please help me with this piece
    By serandre in forum Mastercam
    Last Post: 08-03-2009, 07:01 PM
