587,482 active members*
3,574 visitors online*
Results 1 to 6 of 6
    Jun 2010
    Opinion please?
    Can anyone tell me why my machine travel in the x is all jagged? It is supposed to be a straight line! Please see attached pics and gcode. I start in Corel Draw, then to Cut 2D and then to Mach 3. Does anyone see anything in the gcode, or do you think it is a setting in Mach?
    Thank you in advance for your time.
    Attached Files Attached Files
    Apr 2004
    5749
    It looks like mechanical weakness in your machine, and lack of rigidity. What sort of machine is it? Did you build it yourself? What are you using for a spindle, what sort of tool is in it, and how deep are you trying to cut at a time?
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Jun 2010
    I have just a small hobby machine, no I did not build it myself. There is no "slop" in it - everything is tight. Trying to cut .25" at a time. Actually my problem is in the y, not in the x as previously stated. As it is moving in the x, the y is varying when it is supposed to be remaining constant.
    Jun 2010
    upon further inspection of my mach3 software, I discovered I had the backlash for the y set for .037. Could this have been the problem? I will find out tomorrow.
    35538
    The g-code is definitely not a straight line, and it's possible that the backlash comp and maybe a lack of machine rigidity is making it worse.
    The jagged lines are most likely due to your original drawing in Corel.
    Jun 2010
    problem solved - it was the backlash compinsation setting
    Thanks!!
  1. No opinion!
    By bfreesebfreese in forum Commercial CNC Wood Routers
    Last Post: 02-05-2007, 05:28 PM
  2. Your Opinion Please....
    By jaybee101 in forum Benchtop Machines
    Last Post: 02-02-2007, 11:20 PM
  3. Need opinion
    By diemaker1 in forum MetalWork Discussion
    Last Post: 06-10-2006, 01:37 AM
  4. Your Opinion Please
    By Barefooter in forum Uncategorised CAM Discussion
    Last Post: 09-06-2005, 02:58 PM
  5. Need Opinion
    By Builder in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2004, 11:13 PM
