Originally Posted by
louieatienza
To add to this, you can do your pocketing with climb cuts, and leave .01" or so for finishing. Then you can do a finish pass using conventional cuts. The climb cut will leave your part with a slightly minus tolerance, and when yo do the finish pass, there won't be enough material cut to "pull" the bit in considerably.
As for the bit, looks like the tip is discolored from excess heat. You can try a single-edge spiral "O"-flute bit at the same RPM or a little higher, with more cut depth per pass.
As for climb vs. conventional: climb cutting is when the bit is rotating in the same direction as the tool, as if the bit was a tire rolling on the road; conventional cutting is when the bit is rotating opposite the tool direction.
