No no don't get it wrong. I have used the smooth stepper before and it works great, I'm just saying the backlash comp plugin has some kinks. The smooth stepper its self is awesome, I would recommend it to anyone. The best part is the USB interface.
I know me too. It blows away the parallel port on performance, but if you didn't have a means of zero backlash i.e. double ball nut. It's wasn't a viable solution. Now that it has backlash support I think you will see it more.
Got the x and y up and running. It's only at 66% of max speed due to the parallel port, but still way faster then I need. Here is a little video. Hope to have the z up and running next weekend.
bccde710.mp4 video by sdubfid - Photobucket
Yah I noticed that too. It's my x-axis that is louder. I was just happy to have it working. But I also remember not lubing the x like the y so I'm going to try that next weekend, hopefully thats all it is.
Is it safe to use grease on the ballscrews? When I took the ballnuts apart they had grease from the factory. I was even considering greasing the ways instead of using oil. Any issues with this?
You can use grease, but keep in mind, grease is tacky and it will collect chips a lot more then using oil.
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
sweet finally got to cut some aluminum with it
I cut a 2' diameter circle in a 3/8" plate.
it came out within .0015" and there were no marks or divots where the axes reverse rotation. Pretty darn good for the first part.
Won't be able to update for a month as I'm starting a new job and moving.
Hopefully Hoss will have some new plans out by then that I can buy.
Been a long time since any updates. I got the machine working and have engraved a few things and done some random stuff. Still have a bunch of work and tidying up to do.
I picked up a dmm 750w servo today to use as my spindle motor. My stock motor is an early grizzly 750w motor.
I will be doing belt drive too. Max rpm will be 6000rpm. DIYENGINEER has already upgraded my spindle bearings. Servo motor max rpm is 1000rpm with their old servo drives. With the new servo drive it will do ~3000rpm 110v and ~5000rpm 220v. I will be running 110v and 1:2 ratio probably with a gt2 belt. Should be a good combo for tapping.
Believe me I understand the issues with finding time to pursue such things while working. It is not easy at all!
Did you ever get rid of the MTW mill? I see it is still have it listed.
it is looking good though!
Why stick with the same power range? This mill is really nice and should handle a larger motor well, especially if you gear it up for higher speeds.I picked up a dmm 750w servo today to use as my spindle motor. My stock motor is an early grizzly 750w motor.
I'd go for 220v myself.I will be doing belt drive too. Max rpm will be 6000rpm. DIYENGINEER has already upgraded my spindle bearings. Servo motor max rpm is 1000rpm with their old servo drives. With the new servo drive it will do ~3000rpm 110v and ~5000rpm 220v. I will be running 110v and 1:2 ratio probably with a gt2 belt. Should be a good combo for tapping.
haha should be 2" not 2'. Machine worked awesome interpolating some 3" holes in 6061. Now I will get to weld the machined parts when I'm back from europe in July.
Any updates?
Sorry to hear about the move. Nobody deserves to live in the Mac.
I'm sure you got killer pay work up there though. I was this ~> <~ close to going there myself,but the position fell through.
Email me a list of what you've got,and what you want for it. I'm in North Delta (15 minutes from Vancouver).
Ahh that sucks!![]()
