587,303 active members*
3,358 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Learning Gibbs Engraving
Results 1 to 9 of 9
    Jun 2011
    13
    Hi guys,
    I am new to gibbs and try to learn gibbs 4th axis. How do i engrave text which wrap around a cylinder? Please Help. Thanks
    F-STOP
    May 2012
    85
    Quote Originally Posted by F-Stop View Post
    Hi guys,
    F-STOP
    You need simultanious 4 axis post.
    create a solid the outer dia of what you are to engrave.
    create your engrave geometry.
    select the solid and geometey .
    if all set up is correct it will engrave about A or B axis
    good luck
    Jun 2003
    513
    You need the Polar & Cylindrical Milling (Rotary Mill) option and the rotary mill post.
    Mar 2010
    8
    What about using the "wrap" button to wrap the geometry around the stock?
    Jun 2003
    513
    You don't need to view geometry as wrapped to machine it in rotary mill mode. The workgroup containing the geometry must be set as Wrapped, and Polar & Cylindrical Milling must be checked in the Rotate tab.
    Jun 2011
    13
    I got the toolpath and the engraving work on the machine. but 1 problem that all the wording is backward. When i cut part rendering, everything look the way it supose to be. but when i tried to run on machine, everything is oposite. What did i do wrong? Thanks guys
    Jun 2003
    513
    Is the rotary axis direction going the correct way in the rotary axis setup page?
    Jun 2011
    13
    I think the set up is corrected. I enclosed the file i want to engrave. Thanks for your help
    Attached Files Attached Files
    Feb 2011
    80
    I believe cadman is correct. You have your rotary defined in the wrong direction. See screenshot attached.
    montie
  1. PHCAD setting cut after engraving deeper engraving
    By herby08 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2012, 10:18 AM
  2. Learning CNC
    By clayman in forum MetalWork Discussion
    Last Post: 02-23-2012, 09:21 PM
  3. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
  4. Learning!
    By cncadmin in forum EnRoute
    Last Post: 11-09-2011, 12:54 AM
  5. Learning...Need help with PSU
    By h3ndrix in forum CNC Machine Related Electronics
    Last Post: 02-24-2007, 11:38 PM
