All day while waiting to get home and run some tests I started thinking just how many things I've changed and all the settings I've tried. I figured it was time to go through everything and reset everything to what a 'default standard' config would be, ensure everthing was set per the manuals and even double check the wiring while I was at it.
Well, I came home and figured I'd set up a dial indicator and measure the Y axis (which was the Z axis logic/driver path. Well, it was off.
I have to admit here that I never did take any precise measurements of the X or Y travels. The progression went like this.
I got the machine set up and wanted a job to give it a workout. I chose the Aztec calendar floating around this site.
I set up a V-carve toolpath and loaded up some MDF for cutting. That's when I noticed the Z was changing. Over the course of a couple of weeks I continued to check/tweak some things and re-run the job after re-referencing to my home switches. Many, many times I turned everything off then came back later and turned it on, re-zeroed and re-cut the job with the workpiece never having been moved. I marvellled at how repeatable the switches were as other than the Z everything recut at the correct position. The jobs were run for various lengths of time never quite finishing before I would kill it.
This is with a design with lots of circles and sub-designs in circular arrays. The recuts along the X and Y were always right on so I never checked them.
So I don't know if things have changed or if this was always there. Frankly I don't see how it could have rerun the job so perfectly if it was off that much and varied with the job run time, but I don't KNOW that.
Anyhow, that's the story. Now for todays results.
I set up a dial indicator on each axis and referenced it. Then for each axis I ran a file that moved that one axis 1 inch and then returned. I repeated this cycle 50 times. Then moved it back to the reference point and took a reading.
Each test cycle was run twice on each axis and each run was within a thousandth of the each other.
Y Axis: 10,11 thousandths in the negative direction after run
X Axis: 21,22 thousandths in the positive direction after run
Here's the surprising one
Z axis: 0,0 after each run.
So, I'm not sure what this tells me but I'm thinking I do need to do a reset to baseline and proceed from there.
Any thoughts?
BobL.
