588,202 active members*
4,604 visitors online*
Thread: Relay wiring
Results 1 to 9 of 9
    Jul 2004
    442
    Relay wiring
    I have some solid state relays, 5V to 115V that I want to use with a Mach 3 setup. One of them will operate an air solenoid that controls a spindle brake.
    I've read that there could be a problem when the coil is turned off, (harmful back voltage ????)?
    Please advise any simple way to avoid problems.
    I'm electronically impaired, so please be explicit.
    Thanks,
    Ozzie
    Feb 2009
    6028
    Shouldn't be an issue with solid state. It's usually a problem with the dry contact relays. That's why I buy those with the built in led indicator light. Acts like a diode suppressor.
    Dec 2003
    24220
    For AC inductive devices, use an RC snubber (search here for snubber) , for DC a Diode such as the 1N4000 series.
    The coil or inductance in each produces a BEMF spike that can cause noise problems.
    See post #2. http://www.cnczone.com/forums/genera...ion_error.html
    http://www.electronics-project-design.com/diodes.html
    Al.
    Albert E.
    Oct 2008
    406
    Don't worry about it. Solid state relays don't have a coil so there's no possibility of any inductive kick.
    Bob
    "Bad decisions make good stories."
    Dec 2003
    24220
    Quote Originally Posted by bobsch View Post
    I think he is referring to the (inductive) devices they are switching?
    Al.
    Albert E.
    Feb 2009
    6028
    Still solid state. No arc.
    Dec 2003
    24220
    There is BEMF across the coil of an inductive device at switch off.
    Look at any Manufacturer engineering notes that will show when any SS device switches an inductive load there will be Overvoltage transients, the faster the switch, the higher the transient.
    Some SSR's have a clamp diode or other across the switching device but it is always best to play safe.
    http://www.crydom.com/en/Tech/Tips/D...guidelines.pdf
    see last paragraph. http://www.crydom.com/en/Tech/Newsle...20an%20SSR.pdf
    Al.
    Albert E.
    Oct 2008
    406
    Al.
    Good points. I was thinking of the input, not the output side of the relay. Thanks for the tips from Crydom, too.
    Bob
    Sep 2005
    1195
    SSR 25A
    Do you mean like this attached. If you use PMDX 126, there is in manual about using it.
  1. Wiring Aux 1 relay
    By SWATH in forum Mikinimech
    Last Post: 02-29-2012, 07:26 PM
  2. Probe Wiring with Relay?.
    By mick-uk in forum DIY CNC Router Table Machines
    Last Post: 10-23-2011, 11:29 PM
  3. embarassing relay wiring question
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 01-15-2009, 02:40 AM
  4. TREE 310/325 Relay wiring diagram
    By ken fedirko in forum Tree
    Last Post: 02-10-2008, 05:55 PM
  5. Wiring a relay into my 3 phase motor
    By Bass_Player in forum CNC Machine Related Electronics
    Last Post: 05-24-2005, 03:50 PM
