588,156 active members*
5,316 visitors online*
Results 1 to 14 of 14
    Mar 2004
    222
    transformer from UPS?
    can I use a transformer from a UPS? (Uninterruptible Power Supply)
    I acquired an APC 520ES UPS, and looking
    inside it I found a huge transformer, and I was wondering
    if I could use it as a power supply, if so, what current
    capability can I expect from it? I'm guessing it's
    a kind of step-up transformer, but does it work the other
    way?
    thanx.
    mhel
    "This is intentionally left blank."
    May 2005
    925
    I used one from an UPS, but I rewired it (actually a shop did it )so I can have multiple secondaries:
    Pablo
    Mar 2004
    222
    I got brave enough and tried it,
    with the transformer that I have
    I'm getting 16V AC not using the center tap
    so, basically I have two 8V which would drop
    when I use bridge rectifier. I might try rewinding,
    but need to do a lot more reading from the other thread.
    Actually I just wanted to build a bench PSU so I guess 12VDC
    should be enough for now, I'm just curious how much current this
    thing could handle.
    mhel
    Mar 2005
    523
    with bench supplies you very seldom need much more that 1 or 2 amps.
    maybe you should consider using a variac with its o/p into a bridge/ cap filter setup for larger current needs.
    you can feed the variac into transformers as well.
    this way one can bring the ac/dc up slowly in experimental circuits, before the fireworks.
    been there , done that , lol
    Mar 2004
    222
    I forgot about this.
    I'm reviving the thread for yet another question.
    BTW I built a simple PSU using LM317 and a walwart trnsformer,
    found a circuit online.
    My new quest.
    I decided to use the txformer from UPS to power
    my steppers( currently have one), but I'm
    not quite sure how much current it could supply.
    How do I determine the current.
    this txformer used to have two 6Ah batteries connected
    to it( though not directly).
    Also can bridge rectifiers be paralleled, ( I'm thinking I could,
    since diodes could be paralleled right?) I just happen to have
    a bunch I took from old AT PSUs, and I'm cheap I'm trying
    (to save)let me rephrase, not to spend as much
    If it could be paralleled, I still need to know the current from the txformer.
    The bridges I have can handle 4A, (it says so in the datasheet I got).
    tia.
    BTW why(how come)does some transformer hum? 'cause this one hum
    noticeably.
    mhel
    Apr 2005
    281
    If you have 16vac without the centre tap you should get 16vdc using a bridge rectifier. Connect your 2 ac lines from the transformer to the ac lines on the bridge and there should be a + - on the bridge for your dc out. The rectifiers I have seen are all marked.
    Hope this helps.
    John
    Mar 2004
    222
    vulcom1:
    thanks, but I'm more concern 'bout current capability
    of the transformer, and the possibility of using
    two bridge rectifier parallel.( and the humming )
    but I guess the hum is no big deal, I hear the
    the transformer on the lamp post accross the street when
    I walk by, nobody seems to care.
    mhel
    Dec 2003
    24220
    You can get an idea of the VA from the physical size of the core. Transformer hum is often caused by either loose laminations or also increases when under load.
    Al.
    Albert E.
    1695
    Diodes cannot be hooked in parallel. They will not split the load equally.
    Mar 2004
    222
    Dang, I was hoping I could make use of those bridges if
    the txformer is more than 4A
    Al_The_Man: I just thought that I could derive the value
    from available info i.e. 6Ah batteries used, and the unit's
    output is [email protected] when it's still a UPS as you
    can see in the pic it's been stripped off.
    .thanks.
    mhel
    Dec 2003
    24220
    There's no definitive rule, but I would guess the size to be around 200~250va tops.
    Al.
    Albert E.
    Mar 2004
    222
    I'll try to test it like this, say, I use the bridge that is rated 4A,
    would the bridge blow up if the txformer can supply more than 4A,
    or do I have to put load first then I'll know if it will blowup?
    That way I could assume that I have more than 4A txformer,
    then figure up another test
    mhel
    Dec 2003
    24220
    The current is dependant on the load, no load - no current.
    If you exceed the va rating of the transformer it will overheat and the voltage may start to collapse.
    Al.
    Albert E.
    Mar 2004
    222
    Thanks, I should have known that, still a lot to learn.
    mhel
