588,648 active members*
5,204 visitors online*
Results 1 to 8 of 8
    Feb 2010
    331
    help referencing home (advanced)
    i have mach3 and its working great. i just got my home and limit switches all set up and everything works as it should. however i have a special requirement.
    i need the z axis to move to its midpoint BEFORE the y axis references its home position.
    so gurus of mach3 what is the best way to accomplish this?
    35538
    Change your homing script to this. This will move down 2" before the Y homes. Edit the "2" to the correct value you need.
    DoButton(24)
    Code "G53 G0 Z-2"
    While IsMoving()
    Wend
    DoButton(23)
    DoButton(22)
    May 2010
    313
    ger21, dont you need this too?
    DoButton(24)
    While IsMoving()
    Wend
    Code "G53 G0 Z-2"
    While IsMoving()
    Wend
    DoButton(23)
    DoButton(22)
    John
    ps and how would you get x&y to home at same time?
    35538
    No, not when homing. The default homing scripts don't use it.
    RefCombination(3) will home X and Y together.
    Feb 2010
    331
    i had some time to play with this, i ended up having to use woodspinner's code. gerry's resulted in the z moving down 2 inches BEFORE it referenced home.
    this now works perfectly, thank you both for your help so far.
    now i have another issue. when homing the x axis i get an error saying a limit has been tripped. i have the x axis home and limit switch as the same physical switch.
    i have tried
    changing the order which the axes home: no effect
    i disabled the switch as a limit: this homes correctly, but of course i then have no limit switch.
    any idea on how to fix this?
    35538
    It's probably noise or switch bounce triggering the limit immediately after homing.
    It shouldn't, because it's exactly how I have mine setup?
    Feb 2010
    331
    i can watch the read out in the diagnostics and it works as it should.
    in either case, what would i do about it?
    35538
    You can try adding a small capacitor to the input, or try a different switch. I use the electronic home switches and they work great, no problems at all.
  1. Issue with referencing the 770
    By concombrefrais in forum Tormach Personal CNC Mill
    Last Post: 08-17-2011, 05:09 PM
  2. 'Z' Referencing with Plasma THC
    By Normsthename in forum BobCad-Cam
    Last Post: 09-01-2009, 09:57 PM
  3. 18i-TA zero return (home referencing)
    By padobranac in forum Fanuc
    Last Post: 03-18-2009, 09:31 PM
  4. Zero Referencing
    By br1 in forum Mach Mill
    Last Post: 03-05-2009, 01:17 AM
  5. Re-referencing a machine with APC
    By sinha_nsit in forum Fanuc
    Last Post: 10-08-2008, 06:21 AM
