588,603 active members*
9,800 visitors online*
Results 1 to 14 of 14
    Feb 2010
    45
    Excitech 1212 plunge rate
    I'm using VCarve files on a 1212 and don't seem to be able to adjust the plunge rate, anyone know if there is a minimum rate from VCarve? Adjusting the rate in VC doesn't seem to have an effect on the machine.
    I'm cutting/drilling brass sheet and going through cutters on the plunge
    Any help much appreciated.
    Cheers
    Phil
    Sep 2009
    27
    You can't do this with de v cave software. Use de DSP controller to adjust plunge rate manual...
    Feb 2010
    45
    Thanks for the reply. I've set the ZdwnRatio to the minimum (0.01) before running the file and changed to a ball cutter which helped. Edge quality is pretty bad but at least it cuts.
    Sep 2009
    27
    Good! That saves you some money on router bits
    Wish the machine could read and execute the programmed plunge/travel/... rate too.
    Anyhow happy routing!
    35538
    Are you saying the machine ignores the feedrate in the g-code when plunging?? That doesn't make any sense.
    VCarve has a plunge rate that's set when you select or edit the tool.
    Sep 2009
    27
    Yups my machine ignores the Travel/cutting/plunge speed. I have to set them manually with my dsp controller...
    35538
    How does it know when it's plunging vs cutting?
    Sep 2009
    27
    Don't know, I have to set my speeds with my dsp controller...
    Mar 2009
    90
    u can set the dsp to read the feeds and speed...plunge rata buy activate the f read function from dsp menu i don't know the exact location but you can
    Feb 2010
    45
    The set up to read Gcode feed rates is done via: Menu - Auto Pro Setup - GCode Read Setup - FRead. Default FRead setting is disable. Button 2 and 6 toggles between disable and enable.
    Manual for MO-CON501 pendant controller here:
    CNC Pendant Controller, CNC Controllers (Powered By StoreSprite.com)
    Sep 2009
    27
    Quote Originally Posted by Inuk View Post
    AHa I'll try that in a minute! Many thanks for the info!
    Sep 2009
    27
    Eureka! It works! Man this helps me a lot getting cleaner cuts faster! Again many thanks!
    Respect,
    JLD
    Feb 2010
    45
    Brilliant, you owe me a pizza from that cool oven next time i'm in your neck of the woods. :cheers:
    Sep 2009
    27
    :cheers: sure always welcome for pizza and beer
  1. What feed/plunge rate for this?
    By alank2 in forum WoodWorking Topics
    Last Post: 05-13-2012, 05:31 AM
  2. Plunge rate in Sheetcam question
    By plain ol Bill in forum Waterjet General Topics
    Last Post: 10-02-2009, 11:48 PM
  3. Control Plunge rate & Retract rate
    By GEORGETOUBALIS in forum G-Code Programing
    Last Post: 04-13-2009, 12:12 PM
  4. Excitech 1212 Setup HELP!!!
    By SEALvet2 in forum Excitech routers
    Last Post: 08-25-2008, 05:00 AM
  5. Pierce Delay And Plunge Rate
    By DISCONNECTED in forum Waterjet General Topics
    Last Post: 01-30-2007, 03:48 AM
