587,401 active members*
3,191 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Ballscrews and linear rail Xaxis - Dual or Single drive?
View Poll Results: How would you drive my x axis?
Voters
42. You may not vote on this poll
  • dual motor on the X axis
    35 83.33%
  • single motor in the middle
    7 16.67%
Page 1 of 2 12
Results 1 to 20 of 31
    Nov 2007
    8
    Greetings all. I'm building a ~ 4"x3" 8020 machine, and using ~32mm ballscrews and THK precision linear rails. I have 2 precision ballscrews outta a decommissioned mill that are matched in every way but length. My impulse is to just dual-drive the x axis to avoid any chance of racking, but my gantry will be, it seems, very rigid, so perhaps centerdriving would be the way to go. What would you do if it were your machine?
    Heres a sort of mockup photo to help with your visualization. Linear bearings not pictured, the steel rail wont be used there
    Apr 2010
    363
    After seeing it both ways I have one honest recommendation.... DUAL! I cannot stress this more. At very minimum, run dual screws and drive them both with a belt, like the Solsyva's do. I switched mine to dual motors and the X and could not believe the difference. Dual screws over a single offer so much more rigidity and accuracy. Looking into the laws of force and torque the math certainly back this claim up.
    That being said, it is possible to run 1 screw. People have done, and some with good success. However, (and this is big) your potential for racking and problems goes thru the roof. Any looseness in your system will show up there on the ends of your gantry.
    All my designs use dual drive. Your free to do your own, but this is my recommendation since you asked.
    Apr 2009
    5516
    It depends on how you're ultimately going to have your system set up. but normally, at even your shortest width 3', you'd probably have to use dual screws unless you space your LM blocks far apart, and then you'd lose travel.
    I'vev asked before if there was an optimal ratio between bearing rail spread and distance between blocks (end to end) that would give good ridgidity without excessively reducing travel. Your system as it sits would have a mechanical disadvantage if the leadscrew is mounted under the table, since it would be at a maximim distance from the bearing blocks IIRC.
    Barring commercial machines, it seems the most successful single leadscrew designs for DIY have the rails 24" or less, and larger widths with two leadscrews or even r&p.
    Nov 2007
    8
    Thanks guys.
    Dual drive seems like it'll still be the way to go then. And really, given how much I hate redoing things, it was foolish to consider not dual driving to begin with.
    Apr 2012
    I do not have a cnc router yet.
    What happens if one of the motors, in a dual X configuration, stops working in the middle of a run?
    Since only one side is working, will it tweak major parts of the machine and require serious repair?
    Aug 2011
    999
    Quote Originally Posted by mmomike View Post
    Probably depends, if the machine or the motors are stronger.
    I had the same concern when I built my machine and I force synchronized both steppers with a belt. This is kind of unusual from what I have seen here but it works very well. In normal operation, the belt is just idling along without load and does not contribute to inaccuracies, but if a motor drops out or worse if it stalls hard, the belt prevents the other motor from twisting the gantry. Another convenience is I can move the x by hand, tugging on the belt or turning the pulleys without the gantry losing perpendicular adjustment.
    Apr 2012
    Has anyone here ever twisted a gantry or worse when a motor went out or stalled?
    Someone must be able to speak from experience.
    ps. JerryBurks, I love your Big Bamboo build. The most visually appealing DIY cnc I've seen.
    Dec 2007
    379
    I had an issues while setting up my machine for dual X drives. The motors were out of sync. One motor stopped moving, the other continued and it permanently damaged my SRB20 Bearing blocks. It has also caused premature wear on my dumpster CNC nuts.
    Aug 2011
    999
    I was not sure about the likelihood of such a problem occurring but I see from the previous post that it does happen. My 1600 in-oz steppers on a 15mm pitch screw can deliver about 1000 pound thrust when going slow (a 381 in-oz stepper on a 10mm ball screw can push about 350 pounds). Although I built a pretty strong machine, I doubt it could take that without damage.
    Apr 2012
    I see the advantages to driving both sides of the x-axis, but LazyMan's experience is frightening.
    I have seen builds with 2 ballscrews for the x-axis being driven with a single motor via 2 timing belts. Are there any disadvantages to driving both side with one motor?
    Seems like the best of both worlds. Both sides are being driven and the chance of driving one side and damaging the machine is reduced.
    I am just a newbie working on a design looking for as much advice as I can get.
    Aug 2011
    999
    I believe this is the more common method. The disadvantage can be (depending on pulley size and belt type) that belt backlash, elasticity, long term stretch and thermal effects can affect the positioning accuracy of the x-axis. I did not like that.
    I rather invested in two dual shaft steppers and 2 drives and coupled them with the single belt for safety. I do not "slave" the 2nd motor in the CNC controller but run both drives parallel on the same controller pulse output. Given same size motors, it gives me also more oomph to swing the heavy gantry around than a single motor.
    Apr 2009
    5516
    Quote Originally Posted by JerryBurks View Post
    I run my two leadscrews with 1 timing belt and pulleys. While there may be stretch or backlash, I don't see it. For all intents and purposes, my system is as backlash free as it can be and I need it to be. Since there is very little friction on the linear bearings, not a lot of force is needed to push evevn a heavy gantry around, and any stretching of belts would be from trying to "push" a tool through the material, or using parameters or cutting material too hard for the machine to handle. Even some very large, heavy commercial machies use timing belts for gear reduction.
    While I probably could use a more powerful motor for my X axis, I get plenty of power and speed. Keep in mind too that a belt can also serve as a damper, isolating vibrations to and from the motor, as well as a way to change gear ratios should the need arise.
    Oct 2005
    58
    There have been many posts with multiple arrangements about using cables to keep the gantry from racking. When I get to building the gantry I will put a cable system in the same as the "Paralex" fence on my Powermatic 66 table saw. I have had it for almost 30 years and only had to adjust it once, I removed the saw top to replace the bearings on the arbor.
    Aug 2010
    686
    Dual all the way. The only reason to go single is if you are moving the table on a small CNC router or Mill.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    Feb 2004
    304
    I was worried about potential damage from 2 motors if one stopped working, and am doing mine like this-
    Aug 2010
    686
    The other should just stall if one quits. On my KRMx02 machine if one stops the other can drive both axis.
    Apr 2009
    5516
    I attempted to stall one of the steppers intentionally as a test of my new dual stepper setup. No permanent damage done, though the gantry had to be resquared, which I actually do now by running it into hard stops (slowly of course) and letting them stall, until I get the homing switches wired up.
    I believe Kevin's design calls for servos, which might cause damage?
    Feb 2004
    304
    Quote Originally Posted by louieatienza View Post
    Mine will use a single servo motor to drive both ballscrews. What do you see as the potential for damage?
    Jan 2012
    Most lead or ball screws have very low backdriving efficiency, which is also dependent on the lead angle or pitch of the screw itself. Some low lead angle screws are even negative backdrive efficiency so a lot of force is needed to overcome it (essentially the nut is fixed for all practical purposes). Not to mention if one drive fails during operation you immediately have huge moments generated to cause lots of friction on the slide. That is also assuming once the drive fails, the servo or stepper acts like an open circuit instead of a close circuit which will otherwise make the screw even harder to turn.
    35538
    Quote Originally Posted by kevincnc View Post
    He means if you were using 2 servos.
Page 1 of 2 12
  1. Dual drive single axis
    By BZee in forum DIY CNC Router Table Machines
    Last Post: 04-14-2014, 08:42 AM
  2. Single vs dual ballscrews?
    By MechanoMan in forum DIY CNC Router Table Machines
    Last Post: 05-02-2012, 05:34 AM
  3. How stiff is a single THK linear rail?
    Last Post: 05-15-2010, 04:44 AM
  4. linear slides X-axis single side or dual?
    By PlasmaGuy in forum Linear and Rotary Motion
    Last Post: 02-16-2006, 06:44 AM
  5. single linear rail?
    By erase42 in forum Linear and Rotary Motion
    Last Post: 01-22-2006, 08:36 PM
