Hello, I am looking to quote the following job.
sean dbg cap.PDF
sean dbg vessel.PDF
I have also attached the drawings here as well, just in case. https://docs.google.com/open?id=0B1H...WdRdnJVMUpsUmM
https://docs.google.com/open?id=0B1H...2x0Wm9qVVNsYkk
I am looking at between 20-50 parts (of each) I would like a quote per part if possible. The drawings are not complete, but should provide you with the information needed. The threaded portion isn't critical, and is open ended, however a fine pitch is preferred ~16 or more TPI. The bottom of the vessel does not need to be completely plate, although a decent surface finish is desired.
The most important aspect of the pieces is the 45 deg mate. This is still experimental, and I hope that it will provide a hermetic seal up to 600C. If there is any reason you feel it won't work, please let me know. Thanks
