587,770 active members*
3,087 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V23 - Pocketing off the part: Easier way???
Page 2 of 3 123
Results 21 to 40 of 48
  1. #21
    Nov 2010
    I never paid attention to the moves generated but they are short, linear, three axis moves and not arcs. When hand coding I can do a helical move and use only 1 G-code block per step. So, if I've done my math right I only need five blocks to get thru the .250" plate while abiding by the 3° max. ramp angle. That, my friends, is much easier to read AND troubleshoot. (BTW - the controller on the machine I'm running this on has 16MB of program memory. The only real limitation is line numbering. If my memory serves me well it's limited to 99,999.) Plus I can center it in the hole thus maintaining a constant cutter load during the finish passes. I'm not sure I could get that with BobCAD and it's spiral entry...
    Is there an option for 'arc moves' in v23?
    I was doing some thread milling a while back, I used to code it by hand but thought I will give Bobcad a go as I had a lot of holes on the part. When I saw the code I couldn't believe how long it was more than 10 times what I program. On revisiting my machining options I saw a box to tick called arc moves, ticking that box and reposting the code was much smaller than before. This was in V24.
    I agree that HSM tool paths are extremely long and do 4 or more arc segments where 1 would do the job.
  2. #22
    Jan 2007
    69
    @ Winna
    If there is I cannot find it.
  3. #23
    Jun 2008
    1838
    Yes there is
    Quote Originally Posted by WCIS View Post
    @ Winna
    It is under "Options" in V23
    Regards
  4. #24
    Jan 2007
    69
    Quote Originally Posted by The Engine Guy View Post
    Regards
    Could you be more specific? The only 'options' I see is in the feature edit form and it only pertains to chamfers. I see nothing in the preferences menu item, nor do I see anything when right clicking milling tools...
    Ah, never mind. I see your graphic now. We (at least I think) are talking about spiral entry when using the pocketing feature.
  5. #25
    Apr 2009
    3376
    The only way I can see to reduce lines of code is change the tolerance value.That will drastically reduce the amount of code generated,But it sure makes for a ugly toolpath.Compare settings at .01,then re-compute with 1.0.Lot less code,But pretty crude spiral entry tool path.Big line segments.I c nothing to make tool path one helical or spiral(like one entity).Talking about V23 Pocketing,Spiral Entry here.
  6. #26
    Jun 2008
    1838
    Quote Originally Posted by jrmach View Post
    Sorry, previous poster was talking about thread milling so I made a wrong assumption.
    To the job in hand, if you want to reduce the amount of code then what you could do is maybe use a curved ramp by selecting "ramp" approach and "circular" lead in. also using more peck depths and a steeper angle of approach will often actually speed things up as faster feed rates can be used, trying to go deep with a Spiral may not always be the best option as the feed rates do have to be a fair bit slower
    This method has worked OK for me in the past
    Regards
  7. #27
    Apr 2008
    1577
    The first thing I wanted to do when scripting was implemented in V23 was to write a spiral(with arcs)/ramp(arc) XYZ entry. But I always thought it would be just a matter of time and the next update would have it. As I stated in another thread here yesterday, I opted to increase my machine's memory size instead
    Could such a script be written to do a spiral -with arcs - pocket entry without all the tiny lines? It doesn't seem that hard but there's probably a reason I never tried it. Still...
  8. #28
    Jun 2008
    1838
    Can be done yes !
    Quote Originally Posted by SBC Cycle View Post
    SBC
    Yes it can be done, here is a sample from a different Cad-CAM software from 2004 vintage so it is "out there" somewhere Just not quite in BobCAD-CAM just yet
    O=(POCKET HELICAL RAMP TEST)
    ( BLOCK STOCK - ALUMINUM. X101.6 Y101.6 Z10 )
    ( T6 = 6MM CARBIDE END MILL )
    (G54 = )
    N6G21G90G40G80G17
    (POCKET2)
    N8G28G91X0Y0F1000
    N9T6M6
    N10M3S400
    N11G4P2
    (6MM CARBIDE END MILL)
    N13G0G90G54X1.964Y7.964S4000M3
    N14G43Z25.0H6M8
    N15Z2.0
    N16G1Z0.25F360.
    N17G3X4.964Y4.964Z0.102R3.0
    N18X7.964Y7.964Z-0.045R3.0
    N19X4.964Y10.964Z-0.193R3.0
    N20X1.964Y7.964Z-0.341R3.0
    N21X4.964Y4.964Z-0.489R3.0
    N22X7.964Y7.964Z-0.636R3.0
    N23X4.964Y10.964Z-0.784R3.0
    N24X1.964Y7.964Z-0.932R3.0
    N25X4.964Y4.964Z-1.08R3.0
    N26X7.964Y7.964Z-1.227R3.0
    N27X4.964Y10.964Z-1.375R3.0
    N28X1.964Y7.964Z-1.523R3.0
    N29X4.964Y4.964Z-1.67R3.0
    N30X7.964Y7.964Z-1.818R3.0
    N31X4.964Y10.964Z-1.966R3.0
    N32X1.964Y7.964Z-2.114R3.0
    N33X4.964Y4.964Z-2.261R3.0
    N34X7.964Y7.964Z-2.409R3.0
    N35X4.964Y10.964Z-2.557R3.0
    N36X1.964Y7.964Z-2.705R3.0
    N37X4.964Y4.964Z-2.852R3.0
    N38X7.964Y7.964Z-3.0R3.0
    This is a 6mm end mill going down 3 mm in a Helical spiral at a max 3 degree angle set to cut CCW which in effect gives a smooth move from the helical to the actual pocketing moves, if set to CW then it would have to change direction for the pocketing moves.
    Changing the angle to 10 degrees produced very few lines of the ramping code :-
    (G54 = )
    N6G21G90G40G80G17
    (POCKET2)
    N8G28G91X0Y0F1000
    N9T6M6
    N10M3S400
    N11G4P2
    N14G43Z25.0H6M8
    N15Z2.0
    N16G1Z0.25F360.
    N17G3X4.964Y4.964Z-0.075R3.0
    N18X7.964Y7.964Z-0.4R3.0
    N19X4.964Y10.964Z-0.725R3.0
    N20X1.964Y7.964Z-1.05R3.0
    N21X4.964Y4.964Z-1.375R3.0
    N22X7.964Y7.964Z-1.7R3.0
    N23X4.964Y10.964Z-2.025R3.0
    N24X1.964Y7.964Z-2.35R3.0
    N25X4.964Y4.964Z-2.675R3.0
    N26X7.964Y7.964Z-3.0R3.0
    N27G1X-12.964F720.
    How about it, ready to get "scripting" again ? ? ?
    Or alternatively how about it BobCAD, can we please have the Helical ramping fixed ? ?
    Regards
  9. #29
    Apr 2008
    1577
    SBC
    (G54 = )
    N6G21G90G40G80G17
    (POCKET2)
    N8G28G91X0Y0F1000
    N9T6M6
    N10M3S400
    N11G4P2
    N14G43Z25.0H6M8
    N15Z2.0
    N16G1Z0.25F360.
    (G54 = )
    N6G21G90G40G80G17
    (POCKET2)
    N8G28G91X0Y0F1000
    N9T6M6
    N10M3S400
    N11G4P2
    N14G43Z25.0H6M8
    N15Z2.0
    N16G1Z0.25F360.
    N27G1X-12.964F720.
    Regards
    Now THAT'S what I'm talking about! It really would be nice. I'm going to hack something quick like (I hope ) just to see if I can get a nice spiral. I will use your code as an example.
  10. #30
    Apr 2008
    1577
    Beginning to remember now
    A lot of stuff is still broken in the scripting engine. And the help file for scripting is still hopelessly outdated.
    First with the help file:
    Took me a while to remember that this section is wrong -
    Code:
    20. BSTR MakeRealString(double RealValue)
    returns:
    String formatted according to post processor file question 414 for metric, or 415 for inch.
    22. BSTR MakeXString(double XValue)
    returns:
    String formatted according to post processor file question 414 for metric, or 415 for inch with defined prefix.
    23. BSTR MakeYString(double YValue)
    returns:
    24. BSTR MakeZString(double ZValue)
    returns:
    The proper variables are
    MILL_MakeXString()
    MILL_MakeYString()
    MILL_MakeZString()
    MILL_MakeRealString()
    The other problem is that MILL_MakeZString() doesn't work. Now I know how to get around it but that was why I stopped before.
    I've actually got decent output now. I just have to do some string formatting and testing at this point. This might be neat.
  11. #31
    Mar 2012
    1570
    SBC,
    Did you report the issues with the scripts?
    Report | BobCAD-CAM
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  12. #32
    Apr 2008
    1577
    Quote Originally Posted by aldepoalo View Post
    SBC,
    Report | BobCAD-CAM
    I reported the help file errors a few years ago. They've made it through every version since.
    I can't remember if I reported the MILL_MakeZString() function. I could never get it to work so I assumed it was me. It wasn't until I saw another user use MakeRealString() as MILL_MakeRealString() that I realized what my problem might be with the ZString function. But since it didn't work either, I gave up.
    It wasn't until last night that I realized that it was only the ZString that wasn't working.
    EDIT: There are quite a few more errors than these in the help files. These are just the ones that are vexing me at the moment. They also exist on the FAQ and knowledge base. There is also and error with one of the arc functions but I haven't checked in years to see if it was fixed.
  13. #33
    Mar 2012
    1570
    If you could please use the link I posted and report the issues you've found I would appreciate it.
    Al
    Al DePoalo
  14. #34
    Apr 2008
    1577
    Al
    Will definitely do Al. Thanks.
  15. #35
    Mar 2012
    1570
    I have a question guys,
    Using the V24 or V25 your can contour ramp with a profile. In many cases this would work for hogging out material, do you agree. And with the V24 or V25 the profile will post helix moves or 3D arcs .
    So, yes having the lead in ramp option post helix or 3D arcs is desired, but couldn't use the profile contour ramp in some cases?
    Al DePoalo
  16. #36
    Jan 2007
    69
    It's when using the spiral entry option on the pocketing feature in V23...
    Generates hundreds of short, linear moves thus generating huge program files when only a handful of blocks/lines will do. Also the spiral entry doesn't mind violating the geometry selected for the pocket.
  17. #37
    Apr 2008
    1577
    You just jogged my memory with this post. If the post is set to break arcs into quadrants (or in the case of two pieces if greater than 180), the scripting engine reports the first arc angle as 360 degrees. Then it gets goofy:
    (the angle reported by MILL_GetArcDegrees() is posted after the move)
    Code:
    Z0.1
    G01 Z0. F42.
    G17 G03 X0. Y0.0935 Z-0.0077 I-0.0935 J0.
    360.000010018024
    G03 X-0.0935 Y0. Z-0.0154 I0. J-0.0935
    20626.4811987065
    G03 X0. Y-0.0935 Z-0.0231 I0.0935 J0.
    1181810.31889219
    G03 X0.0935 Y0. Z-0.0308 I0. J0.0935
    67712743.4575533
    G03 X0. Y0.0935 Z-0.0385 I-0.0935 J0.
    360.000010018024
    G03 X-0.0935 Y0. Z-0.0462 I0. J-0.0935
    20626.4811987065
    G03 X0. Y-0.0935 Z-0.0539 I0.0935 J0.
    1181810.31889219
    G03 X0.0935 Y0. Z-0.0616 I0. J0.0935
    67712743.4575533
    That's a little off topic but since I just now remembered...
    To answer your question, yes it would work in some cases. As a general rule however, I always use the total length of my cutter when possible. If you use ramping, you are really only using the bottom of your cutter. As the cutter wears, it is wearing un-even. This will translate into your finish cutter eventually as the cutter bends because it is removing more material from the bottom of the cut than it is at the top.
    That's why I like the Advanced Rough and Adaptive Rough. All the flute, all the time.
    The wear on the end of the cutter when doing a spiral entry is negligible in most cases.
  18. #38
    Apr 2008
    1577
    Does NOT work on V25! Long story not relevant to this thread, but not my fault.
    Before I mention particulars, let me just say I want some testers for this. This is not complete yet (trust me, it will be better) so don't run it on the machine, Predator Backplotting ONLY!
    NOTES:
    It only post G03 (CCW movement)
    It only posts I and J
    It only posts arcs starting at 0 degrees and ending at 360 (full arcs, CCW)
    It only uses the arc radius field, not the ramp angle (yet)
    It will NOT match the spiral you see on the BobCAD screen!
    It WILL violate the pocket if it starts the spiral on a wall (again, I'm not done yet)
    Lastly,
    IT WORKS! (until you guys find the bugs) It will even post correctly if you have multiple depths set.
    USE:
    All the settings are in the Advanced Posting page of the pocket feature (only). It won't work unless you have selected a Spiral in the "Leads" tab. Make sure you change "Use Spiral with Arcs?" to "YES (Experimental)" and as good practice get in the habit of using the same settings in both the "Adv. Posting" and "Leads" tab.
    Unless someone finds a fatal flaw or no one gives me feedback, I will finish this. But not until I get some feedback.
    Eventually, I will implement a function I wrote that will read the tiny lines and convert them into real arcs. Then it will actually match the Verify in BobCAD. I think this is important to the workflow. But again, I'm just trying to get the mechanics of the script to work right first.
    Have fun!
    Attached Files Attached Files
  19. #39
    Apr 2008
    1577
    Here's an example of the code savings. Original code is 548 NC lines:
    Code:
    O00100 ( PROGRAM NUMBER)
    ( BEGIN PREDATOR NC HEADER)
    ( MACH_FILE=4AXVMILL.MCH)
    ( MTOOL T1 S1 D.5 H3. A0. C0. DIAM_OFFSET 1 = .25)
    ( MTOOL T2 S1 D.5 H3. A0. C0. DIAM_OFFSET 2 = .25)
    ( SBOX X-2.5 Y-2.5 Z-1. L9. W5. H1.)
    ( END PREDATOR NC HEADER)
    ( PROGRAM NAME - MEASURE_ARC_ANGLE.NC)
    ( POST -  STANDARD RS-274D GCODE)
    ( DATE - WED. 07/25/2012)
    ( TIME - 03:57PM)
    N01 G00 G17 G20 G40 G49 G80 G90
    ( FIRST TOOL - FIRST CUT)
    (JOB 1  POCKET)
    (FEATURE POCKET)
    N02 T01 M06
    N03 G90 G54 X.04 Y.196 S595 M03
    N04 G43 H01 Z.1 M08
    N05 G01 Z0. F3.3369
    N06 X.0416 Y.2073 Z-.001
    N07 X.0418 Y.2173 Z-.0019
    N08 X.0409 Y.2271 Z-.0027
    N09 X.0393 Y.2355 Z-.0035
    N10 X.0367 Y.2443 Z-.0043
    N11 X.0324 Y.2546 Z-.0053
    N12 X.0273 Y.2634 Z-.0062
    N13 X.0203 Y.2729 Z-.0072
    N14 X.0145 Y.2791 Z-.0079
    N15 X.0067 Y.286 Z-.0088
    N16 X-.0025 Y.2922 Z-.0098
    N17 X-.0122 Y.2973 Z-.0108
    N18 X-.0215 Y.3008 Z-.0116
    N19 X-.0326 Y.3036 Z-.0126
    N20 X-.0424 Y.3049 Z-.0135
    N21 X-.053 Y.305 Z-.0144
    N22 X-.0637 Y.3039 Z-.0154
    N23 X-.075 Y.3013 Z-.0164
    N24 X-.0864 Y.2971 Z-.0175
    N25 X-.0954 Y.2925 Z-.0183
    N26 X-.103 Y.2874 Z-.0191
    N27 X-.1102 Y.2816 Z-.02
    N28 X-.1172 Y.2745 Z-.0208
    N29 X-.1241 Y.2657 Z-.0218
    N30 X-.13 Y.2557 Z-.0228
    N31 X-.1345 Y.2455 Z-.0238
    N32 X-.1372 Y.237 Z-.0246
    N33 X-.1391 Y.2275 Z-.0254
    N34 X-.14 Y.211 Z-.0269
    N35 X-.1393 Y.2021 Z-.0277
    N36 X-.1378 Y.1938 Z-.0284
    N37 X-.1352 Y.1848 Z-.0292
    N38 X-.132 Y.1768 Z-.03
    N39 X-.1281 Y.1691 Z-.0307
    N40 X-.1234 Y.1617 Z-.0315
    N41 X-.1175 Y.1542 Z-.0323
    N42 X-.1107 Y.1472 Z-.0332
    N43 X-.1038 Y.1415 Z-.034
    N44 X-.0951 Y.1357 Z-.0349
    N45 X-.0853 Y.1307 Z-.0359
    N46 X-.0752 Y.127 Z-.0368
    N47 X-.0657 Y.1247 Z-.0376
    N48 X-.0548 Y.1234 Z-.0386
    N49 X-.0441 Z-.0395
    N50 X-.0354 Y.1242 Z-.0403
    N51 X-.0266 Y.126 Z-.0411
    N52 X-.0168 Y.1291 Z-.042
    N53 X-.0028 Y.1359 Z-.0434
    N54 X.0099 Y.1449 Z-.0447
    N55 X.0194 Y.1543 Z-.0459
    N56 X.0285 Y.1667 Z-.0472
    N57 X.0359 Y.1819 Z-.0487
    N58 X.0388 Y.1909 Z-.0495
    N59 X.0405 Y.1986 Z-.0502
    N60 X.0417 Y.2092 Z-.0512
    N61 Y.2185 Z-.052
    N62 X.041 Y.2265 Z-.0527
    N63 X.0393 Y.2355 Z-.0535
    N64 X.0364 Y.2451 Z-.0544
    N65 X.0326 Y.254 Z-.0552
    N66 X.0271 Y.2638 Z-.0562
    N67 X.021 Y.2721 Z-.0571
    N68 X.0134 Y.2803 Z-.0581
    N69 X.0059 Y.2866 Z-.0589
    N70 X-.0035 Y.2929 Z-.0599
    N71 X-.013 Y.2976 Z-.0609
    N72 X-.0238 Y.3015 Z-.0619
    N73 X-.0348 Y.304 Z-.0628
    N74 X-.0441 Y.305 Z-.0637
    N75 X-.0539 Z-.0645
    N76 X-.0621 Y.3042 Z-.0652
    N77 X-.071 Y.3024 Z-.066
    N78 X-.0798 Y.2998 Z-.0668
    N79 X-.0876 Y.2966 Z-.0676
    N80 X-.0973 Y.2913 Z-.0685
    N81 X-.1063 Y.2849 Z-.0695
    N82 X-.1155 Y.2763 Z-.0706
    N83 X-.1222 Y.2683 Z-.0715
    N84 X-.1273 Y.2606 Z-.0723
    N85 X-.1322 Y.2512 Z-.0733
    N86 X-.1358 Y.2418 Z-.0741
    N87 X-.1382 Y.2326 Z-.075
    N88 X-.14 Y.2165 Z-.0764
    N89 X-.1398 Y.2074 Z-.0772
    N90 X-.1386 Y.1976 Z-.0781
    N91 X-.1364 Y.1887 Z-.0789
    N92 X-.1329 Y.1787 Z-.0798
    N93 X-.128 Y.1688 Z-.0808
    N94 X-.1224 Y.1603 Z-.0816
    N95 X-.1114 Y.1478 Z-.0831
    N96 X-.1031 Y.141 Z-.084
    N97 X-.0954 Y.1359 Z-.0849
    N98 X-.0863 Y.1312 Z-.0857
    N99 X-.0747 Y.1269 Z-.0868
    N100 X-.0633 Y.1243 Z-.0879
    N101 X-.0529 Y.1233 Z-.0888
    N102 X-.0429 Y.1234 Z-.0896
    N103 X-.0317 Y.1249 Z-.0906
    N104 X-.0213 Y.1275 Z-.0916
    N105 X-.0111 Y.1315 Z-.0925
    N106 X.0005 Y.1379 Z-.0937
    N107 X.0105 Y.1454 Z-.0948
    N108 X.0202 Y.1552 Z-.096
    N109 X.0271 Y.1645 Z-.097
    N110 X.0326 Y.1743 Z-.098
    N111 X.0363 Y.1828 Z-.0988
    N112 X.0394 Y.1931 Z-.0997
    N113 X.0414 Y.2056 Z-.1008
    N114 X.0418 Y.2181 Z-.102
    N115 X.0407 Y.2287 Z-.1029
    N116 X.0382 Y.2398 Z-.1039
    N117 X.0339 Y.2514 Z-.105
    N118 X.0282 Y.2621 Z-.106
    N119 X.0214 Y.2715 Z-.107
    N120 X.0123 Y.2812 Z-.1082
    N121 X.0018 Y.2896 Z-.1094
    N122 X-.0113 Y.2969 Z-.1107
    N123 X-.0235 Y.3014 Z-.1118
    N124 X-.0356 Y.3041 Z-.1129
    N125 X-.0475 Y.3051 Z-.114
    N126 X-.0582 Y.3047 Z-.1149
    N127 X-.068 Y.3031 Z-.1158
    N128 X-.0775 Y.3006 Z-.1166
    N129 X-.0868 Y.297 Z-.1175
    N130 X-.0973 Y.2913 Z-.1185
    N131 X-.1066 Y.2846 Z-.1195
    N132 X-.1143 Y.2776 Z-.1205
    N133 X-.122 Y.2685 Z-.1215
    N134 X-.1294 Y.2569 Z-.1227
    N135 X-.1346 Y.2453 Z-.1238
    N136 X-.1383 Y.232 Z-.125
    N137 X-.1398 Y.2207 Z-.126
    N138 X-.14 Y.2109 Z-.1269
    N139 X-.1389 Y.1997 Z-.1279
    N140 X-.1362 Y.1879 Z-.1289
    N141 X-.1325 Y.1779 Z-.1299
    N142 X-.1251 Y.1642 Z-.1312
    N143 X-.1193 Y.1563 Z-.1321
    N144 X-.1135 Y.1498 Z-.1329
    N145 X-.1064 Y.1435 Z-.1337
    N146 X-.098 Y.1374 Z-.1346
    N147 X-.0897 Y.1327 Z-.1354
    N148 X-.0796 Y.1284 Z-.1364
    N149 X-.0688 Y.1253 Z-.1374
    N150 X-.0596 Y.1238 Z-.1382
    N151 X-.051 Y.1232 Z-.1389
    N152 X-.0417 Y.1235 Z-.1398
    N153 X-.0318 Y.1249 Z-.1406
    N154 X-.0231 Y.127 Z-.1414
    N155 X-.0116 Y.1313 Z-.1425
    N156 X-.0025 Y.136 Z-.1434
    N157 X.0049 Y.1409 Z-.1442
    N158 X.0125 Y.1473 Z-.145
    N159 X.0192 Y.1541 Z-.1459
    N160 X.0249 Y.1613 Z-.1467
    N161 X.0306 Y.1704 Z-.1476
    N162 X.0354 Y.1806 Z-.1486
    N163 X.0389 Y.1911 Z-.1496
    N164 X.041 Y.2019 Z-.1505
    N165 X.0418 Y.2129 Z-.1515
    N166 X.0413 Y.2244 Z-.1525
    N167 X.0396 Y.2342 Z-.1534
    N168 X.0363 Y.2454 Z-.1544
    N169 X.0317 Y.2559 Z-.1554
    N170 X.0264 Y.2648 Z-.1563
    N171 X.0194 Y.2739 Z-.1573
    N172 X.0122 Y.2813 Z-.1582
    N173 X.0044 Y.2877 Z-.1591
    N174 X-.0046 Y.2935 Z-.16
    N175 X-.0163 Y.299 Z-.1612
    N176 X-.0266 Y.3023 Z-.1621
    N177 X-.0358 Y.3041 Z-.1629
    N178 X-.0468 Y.3051 Z-.1639
    N179 X-.0585 Y.3046 Z-.1649
    N180 X-.0686 Y.303 Z-.1658
    N181 X-.0774 Y.3006 Z-.1666
    N182 X-.0877 Y.2965 Z-.1676
    N183 X-.0957 Y.2923 Z-.1684
    N184 X-.1028 Y.2876 Z-.1691
    N185 X-.1149 Y.2769 Z-.1705
    N186 X-.1208 Y.2702 Z-.1713
    N187 X-.1262 Y.2624 Z-.1722
    N188 X-.1319 Y.2519 Z-.1732
    N189 X-.1357 Y.242 Z-.1741
    N190 X-.1385 Y.2312 Z-.1751
    N191 X-.1398 Y.2208 Z-.176
    N192 X-.14 Y.21 Z-.177
    N193 X-.1391 Y.2006 Z-.1778
    N194 X-.1365 Y.189 Z-.1788
    N195 X-.1327 Y.1782 Z-.1798
    N196 X-.1291 Y.1708 Z-.1806
    N197 X-.1241 Y.1627 Z-.1814
    N198 X-.1186 Y.1555 Z-.1822
    N199 X-.1118 Y.1483 Z-.1831
    N200 X-.1031 Y.141 Z-.184
    N201 X-.0945 Y.1353 Z-.1849
    N202 X-.0853 Y.1307 Z-.1859
    N203 X-.0769 Y.1275 Z-.1866
    N204 X-.0607 Y.1239 Z-.1881
    N205 X-.0444 Y.1233 Z-.1895
    N206 X-.0279 Y.1257 Z-.191
    N207 X-.0186 Y.1285 Z-.1918
    N208 X-.0094 Y.1323 Z-.1927
    N209 X-.0014 Y.1367 Z-.1935
    N210 X.0073 Y.1428 Z-.1944
    N211 X.0148 Y.1495 Z-.1953
    N212 X.0227 Y.1583 Z-.1963
    N213 X.028 Y.166 Z-.1972
    N214 X.0319 Y.1729 Z-.1979
    N215 X.036 Y.182 Z-.1987
    N216 X.0386 Y.19 Z-.1995
    N217 X.0404 Y.1983 Z-.2002
    N218 X.0417 Y.2086 Z-.2011
    N219 X.0417 Y.2188 Z-.202
    N220 X.0406 Y.2294 Z-.2029
    N221 X.0383 Y.2393 Z-.2038
    N222 X.0352 Y.2483 Z-.2047
    N223 X.0301 Y.2588 Z-.2057
    N224 X.0247 Y.2673 Z-.2066
    N225 X.0183 Y.2753 Z-.2075
    N226 X.0112 Y.2823 Z-.2083
    N227 X.0043 Y.2878 Z-.2091
    N228 X-.0035 Y.2928 Z-.2099
    N229 X-.0187 Y.2999 Z-.2114
    N230 X-.029 Y.3029 Z-.2123
    N231 X-.0381 Y.3044 Z-.2131
    N232 X-.0478 Y.3051 Z-.214
    N233 X-.0574 Y.3047 Z-.2148
    N234 X-.0663 Y.3035 Z-.2156
    N235 X-.0743 Y.3016 Z-.2163
    N236 X-.0886 Y.2961 Z-.2177
    N237 X-.0969 Y.2915 Z-.2185
    N238 X-.1043 Y.2864 Z-.2193
    N239 X-.1107 Y.2811 Z-.22
    N240 X-.1176 Y.2741 Z-.2209
    N241 X-.1266 Y.2619 Z-.2222
    N242 X-.134 Y.2469 Z-.2237
    N243 X-.1384 Y.2316 Z-.2251
    N244 X-.1398 Y.2214 Z-.226
    N245 X-.1399 Y.2093 Z-.227
    N246 X-.1391 Y.2006 Z-.2278
    N247 X-.1369 Y.1905 Z-.2287
    N248 X-.1331 Y.1792 Z-.2297
    N249 X-.1284 Y.1696 Z-.2307
    N250 X-.1235 Y.1618 Z-.2315
    N251 X-.1177 Y.1544 Z-.2323
    N252 X-.1108 Y.1473 Z-.2332
    N253 X-.1024 Y.1404 Z-.2341
    N254 X-.0938 Y.1349 Z-.235
    N255 X-.0836 Y.13 Z-.236
    N256 X-.0724 Y.1262 Z-.237
    N257 X-.0614 Y.124 Z-.238
    N258 X-.0491 Y.1232 Z-.2391
    N259 X-.0351 Y.1243 Z-.2403
    N260 X-.0205 Y.1278 Z-.2416
    N261 X-.0088 Y.1326 Z-.2428
    N262 X.0036 Y.14 Z-.244
    N263 X.0142 Y.1488 Z-.2452
    N264 X.0228 Y.1585 Z-.2464
    N265 X.0299 Y.1691 Z-.2475
    N266 X.0345 Y.1783 Z-.2484
    N267 X.0383 Y.189 Z-.2494
    N268 X.0407 Y.1997 Z-.2503
    N269 X.0418 Y.212 Z-.2514
    N270 X.0415 Y.2225 Z-.2523
    N271 X.0399 Y.2326 Z-.2532
    N272 X.0365 Y.2448 Z-.2543
    N273 X.0317 Y.2558 Z-.2554
    N274 X.024 Y.2683 Z-.2567
    N275 X.0151 Y.2786 Z-.2579
    N276 X.0042 Y.2878 Z-.2591
    N277 X-.0059 Y.2942 Z-.2602
    N278 X-.0208 Y.3006 Z-.2616
    N279 X-.0337 Y.3038 Z-.2627
    N280 X-.0472 Y.3051 Z-.2639
    N281 X-.0609 Y.3043 Z-.2651
    N282 X-.0727 Y.302 Z-.2662
    N283 X-.0863 Y.2971 Z-.2675
    N284 X-.098 Y.2909 Z-.2686
    N285 X-.1078 Y.2837 Z-.2697
    N286 X-.1154 Y.2764 Z-.2706
    N287 X-.1225 Y.2679 Z-.2716
    N288 X-.1287 Y.2582 Z-.2726
    N289 X-.1338 Y.2474 Z-.2736
    N290 X-.1377 Y.2347 Z-.2748
    N291 X-.1397 Y.2228 Z-.2758
    N292 X-.14 Y.2112 Z-.2769
    N293 X-.1387 Y.1984 Z-.278
    N294 X-.1354 Y.1854 Z-.2792
    N295 X-.1299 Y.1724 Z-.2804
    N296 X-.1218 Y.1595 Z-.2817
    N297 X-.1161 Y.1526 Z-.2825
    N298 X-.1102 Y.1468 Z-.2832
    N299 X-.1002 Y.1389 Z-.2844
    N300 X-.0873 Y.1316 Z-.2857
    N301 X-.0772 Y.1276 Z-.2866
    N302 X-.066 Y.1248 Z-.2876
    N303 X-.0544 Y.1233 Z-.2886
    N304 X-.0423 Y.1234 Z-.2897
    N305 X-.0288 Y.1255 Z-.2909
    N306 X-.0141 Y.1302 Z-.2922
    N307 X-.0019 Y.1364 Z-.2935
    N308 X.0087 Y.1439 Z-.2946
    N309 X.0181 Y.1529 Z-.2957
    N310 X.0256 Y.1623 Z-.2968
    N311 X.0312 Y.1715 Z-.2977
    N312 X.0354 Y.1805 Z-.2986
    N313 X.0389 Y.1912 Z-.2996
    N314 X.0409 Y.2009 Z-.3004
    N315 X.0418 Y.2131 Z-.3015
    N316 X.041 Y.2262 Z-.3027
    N317 X.0396 Y.2344 Z-.3034
    N318 X.0368 Y.244 Z-.3043
    N319 X.0332 Y.2528 Z-.3051
    N320 X.029 Y.2607 Z-.3059
    N321 X.0233 Y.2692 Z-.3068
    N322 X.0175 Y.2761 Z-.3076
    N323 X.0094 Y.2838 Z-.3085
    N324 X.0021 Y.2893 Z-.3093
    N325 X-.0084 Y.2955 Z-.3104
    N326 X-.0207 Y.3005 Z-.3116
    N327 X-.0337 Y.3038 Z-.3127
    N328 X-.0477 Y.3051 Z-.314
    N329 X-.0624 Y.3041 Z-.3153
    N330 X-.0748 Y.3014 Z-.3164
    N331 X-.0884 Y.2962 Z-.3177
    N332 X-.1 Y.2895 Z-.3188
    N333 X-.1103 Y.2815 Z-.32
    N334 X-.1189 Y.2724 Z-.3211
    N335 X-.1262 Y.2625 Z-.3221
    N336 X-.1321 Y.2515 Z-.3232
    N337 X-.1362 Y.2406 Z-.3243
    N338 X-.1386 Y.2306 Z-.3252
    N339 X-.1398 Y.221 Z-.326
    N340 X-.1399 Y.2093 Z-.327
    N341 X-.1387 Y.1984 Z-.328
    N342 X-.1356 Y.186 Z-.3291
    N343 X-.1316 Y.1757 Z-.3301
    N344 X-.1271 Y.1674 Z-.3309
    N345 X-.1195 Y.1565 Z-.3321
    N346 X-.1114 Y.1479 Z-.3331
    N347 X-.1025 Y.1405 Z-.3341
    N348 X-.0942 Y.1352 Z-.335
    N349 X-.0834 Y.1299 Z-.336
    N350 X-.0725 Y.1263 Z-.337
    N351 X-.0632 Y.1243 Z-.3379
    N352 X-.0527 Y.1233 Z-.3388
    N353 X-.0434 Y.1234 Z-.3396
    N354 X-.0328 Y.1247 Z-.3405
    N355 X-.0248 Y.1265 Z-.3413
    N356 X-.0156 Y.1296 Z-.3421
    N357 X-.0059 Y.1341 Z-.343
    N358 X.0034 Y.1399 Z-.344
    N359 X.0119 Y.1467 Z-.345
    N360 X.019 Y.1539 Z-.3458
    N361 X.0265 Y.1636 Z-.3469
    N362 X.0322 Y.1735 Z-.3479
    N363 X.0364 Y.1833 Z-.3488
    N364 X.0397 Y.1945 Z-.3499
    N365 X.0416 Y.2077 Z-.351
    N366 X.0417 Y.2197 Z-.3521
    N367 X.04 Y.2322 Z-.3532
    N368 X.0362 Y.2458 Z-.3544
    N369 X.0317 Y.2559 Z-.3554
    N370 X.0247 Y.2672 Z-.3566
    N371 X.017 Y.2766 Z-.3576
    N372 X.0063 Y.2863 Z-.3589
    N373 X-.0034 Y.2928 Z-.3599
    N374 X-.013 Y.2976 Z-.3609
    N375 X-.0242 Y.3016 Z-.3619
    N376 X-.0342 Y.3039 Z-.3628
    N377 X-.046 Y.3051 Z-.3638
    N378 X-.058 Y.3047 Z-.3649
    N379 X-.0731 Y.3019 Z-.3662
    N380 X-.0856 Y.2975 Z-.3674
    N381 X-.0979 Y.2909 Z-.3686
    N382 X-.108 Y.2835 Z-.3697
    N383 X-.1164 Y.2754 Z-.3707
    N384 X-.1242 Y.2655 Z-.3718
    N385 X-.1311 Y.2535 Z-.373
    N386 X-.1356 Y.2422 Z-.3741
    N387 X-.1387 Y.2299 Z-.3752
    N388 X-.1399 Y.2191 Z-.3762
    N389 X-.1398 Y.2071 Z-.3772
    N390 X-.1384 Y.1967 Z-.3781
    N391 X-.1357 Y.1862 Z-.3791
    N392 X-.1308 Y.174 Z-.3802
    N393 X-.1251 Y.1642 Z-.3812
    N394 X-.1169 Y.1535 Z-.3824
    N395 X-.1055 Y.1428 Z-.3838
    N396 X-.094 Y.135 Z-.385
    N397 X-.0847 Y.1305 Z-.3859
    N398 X-.073 Y.1264 Z-.387
    N399 X-.0622 Y.1241 Z-.388
    N400 X-.049 Y.1232 Z-.3891
    N401 X-.0365 Y.1241 Z-.3902
    N402 X-.0216 Y.1274 Z-.3915
    N403 X-.008 Y.133 Z-.3928
    N404 X.0038 Y.1402 Z-.394
    N405 X.0153 Y.1499 Z-.3954
    N406 X.0234 Y.1592 Z-.3964
    N407 X.0304 Y.17 Z-.3976
    N408 X.0362 Y.1827 Z-.3988
    N409 X.0399 Y.1953 Z-.3999
    N410 X.0416 Y.2076 Z-.401
    N411 Y.2212 Z-.4022
    N412 X.0398 Y.2333 Z-.4033
    N413 X.0373 Y.2425 Z-.4041
    N414 X.0341 Y.2508 Z-.4049
    N415 X.0261 Y.2653 Z-.4064
    N416 X.0176 Y.276 Z-.4076
    N417 X.0065 Y.2861 Z-.4089
    N418 X-.0064 Y.2944 Z-.4102
    N419 X-.0193 Y.3001 Z-.4114
    N420 X-.0333 Y.3037 Z-.4127
    N421 X-.0477 Y.3051 Z-.414
    N422 X-.0618 Y.3042 Z-.4152
    N423 X-.0741 Y.3016 Z-.4163
    N424 X-.0861 Y.2972 Z-.4174
    N425 X-.0988 Y.2903 Z-.4187
    N426 X-.11 Y.2817 Z-.4199
    N427 X-.1184 Y.2731 Z-.421
    N428 X-.1258 Y.2631 Z-.4221
    N429 X-.1318 Y.252 Z-.4232
    N430 X-.1355 Y.2427 Z-.4241
    N431 X-.1383 Y.232 Z-.425
    N432 X-.1399 Y.2201 Z-.4261
    N433 Y.2088 Z-.4271
    N434 X-.1385 Y.1974 Z-.4281
    N435 X-.1357 Y.1864 Z-.4291
    N436 X-.1311 Y.1748 Z-.4302
    N437 X-.1236 Y.1619 Z-.4315
    N438 X-.1172 Y.1539 Z-.4324
    N439 X-.1095 Y.1461 Z-.4333
    N440 X-.1007 Y.1392 Z-.4343
    N441 X-.0908 Y.1333 Z-.4353
    N442 X-.0821 Y.1294 Z-.4361
    N443 X-.073 Y.1264 Z-.437
    N444 X-.0624 Y.1242 Z-.4379
    N445 X-.0514 Y.1232 Z-.4389
    N446 X-.0397 Y.1237 Z-.4399
    N447 X-.0296 Y.1253 Z-.4408
    N448 X-.0171 Y.129 Z-.442
    N449 X-.0059 Y.1341 Z-.443
    N450 X.0055 Y.1414 Z-.4442
    N451 X.0149 Y.1495 Z-.4453
    N452 X.0225 Y.1581 Z-.4463
    N453 X.0293 Y.1681 Z-.4474
    N454 X.0355 Y.1809 Z-.4486
    N455 X.0392 Y.1926 Z-.4497
    N456 X.0416 Y.2076 Z-.451
    N457 X.0414 Y.2233 Z-.4524
    N458 X.0392 Y.2359 Z-.4535
    N459 X.0346 Y.2496 Z-.4548
    N460 X.028 Y.2624 Z-.456
    N461 X.0179 Y.2757 Z-.4575
    N462 X.0069 Y.2858 Z-.4588
    N463 X-.0036 Y.2929 Z-.4599
    N464 X-.0157 Y.2987 Z-.4611
    N465 X-.0269 Y.3024 Z-.4621
    N466 X-.0389 Y.3045 Z-.4632
    N467 X-.0525 Y.305 Z-.4644
    N468 X-.0633 Y.304 Z-.4654
    N469 X-.0753 Y.3012 Z-.4664
    N470 X-.0853 Y.2976 Z-.4674
    N471 X-.0963 Y.2919 Z-.4684
    N472 X-.107 Y.2843 Z-.4696
    N473 X-.1156 Y.2762 Z-.4706
    N474 X-.1227 Y.2676 Z-.4716
    N475 X-.1289 Y.2579 Z-.4726
    N476 X-.1345 Y.2454 Z-.4738
    N477 X-.1383 Y.232 Z-.475
    N478 X-.1399 Y.2199 Z-.4761
    N479 X-.1397 Y.2055 Z-.4774
    N480 X-.1373 Y.1918 Z-.4786
    N481 X-.1335 Y.1803 Z-.4796
    N482 X-.1264 Y.1662 Z-.481
    N483 X-.118 Y.1547 Z-.4823
    N484 X-.107 Y.144 Z-.4836
    N485 X-.0963 Y.1364 Z-.4848
    N486 X-.0869 Y.1314 Z-.4857
    N487 X-.0781 Y.1279 Z-.4865
    N488 X-.0681 Y.1252 Z-.4874
    N489 X-.0587 Y.1237 Z-.4883
    N490 X-.045 Y.1233 Z-.4895
    N491 X-.033 Y.1246 Z-.4905
    N492 X-.0223 Y.1272 Z-.4915
    N493 X-.0119 Y.1312 Z-.4925
    N494 X-.0024 Y.1361 Z-.4934
    N495 X.0057 Y.1416 Z-.4942
    N496 X.0121 Y.1469 Z-.495
    N497 X.0191 Y.154 Z-.4959
    N498 X.0264 Y.1635 Z-.4969
    N499 X.032 Y.173 Z-.4979
    N500 X.0371 Y.1853 Z-.499
    N501 X.04 Y.196 Z-.5
    N502 G03 G17 Y-.196 I-.04 J-.196 F6.6738
    N503 G01 X1. Y0.
    N504 X.04 Y.196
    N505 X.09 Y.4409
    N506 G03 Y-.4409 I-.09 J-.4409
    N507 G01 X2.25 Y0.
    N508 X.09 Y.4409
    N509 X.14 Y.6859
    N510 G03 Y-.6859 I-.14 J-.6859
    N511 G01 X3.5 Y0.
    N512 X.14 Y.6859
    N513 X.19 Y.9308
    N514 G03 Y-.9308 I-.19 J-.9308
    N515 G01 X4.75 Y0.
    N516 X.19 Y.9308
    N517 X.24 Y1.1758
    N518 G03 Y-1.1758 I-.24 J-1.1758
    N519 G01 X5.04 Y-.196
    N520 G03 Y.196 I-.04 J.196
    N521 G01 X.24 Y1.1758
    N522 X.29 Y1.4207
    N523 G03 Y-1.4207 I-.29 J-1.4207
    N524 G01 X5.09 Y-.4409
    N525 G03 Y.4409 I-.09 J.4409
    N526 G01 X.29 Y1.4207
    N527 X.34 Y1.6657
    N528 G03 Y-1.6657 I-.34 J-1.6657
    N529 G01 X5.14 Y-.6859
    N530 G03 Y.6859 I-.14 J.6859
    N531 G01 X.34 Y1.6657
    N532 G00 Z.1
    N533 M09
    N534 M05
    N535 G91 G28 Z0.
    N536 M01
    ( NEXT TOOL - NEXT CUT)
    (JOB 1  POCKET)
    (FEATURE POCKET)
    N537 T02 M06
    N538 G90 G54 X.35 Y1.7146 S595 M03
    N539 G43 H02 Z.1 M08
    N540 G01 Z-.5 F1.6685
    N541 G03 G17 Y-1.7146 I-.35 J-1.7146 F3.3369
    N542 G01 X5.15 Y-.7348
    N543 G03 Y.7348 I-.15 J.7348
    N544 G01 X.35 Y1.7146
    N545 G00 Z.1
    N546 M05
    N547 G91 G28 Z0.
    N548 T01 M06
    ( RELOAD FIRST TOOL)
    ( END OF FILE)
    ( END OF PROGRAM)
    N549 M30
    The new code is only 63 NC lines long:
    Code:
    ( TIME - 03:59PM)
    (JOB 1  POCKET)
    (FEATURE POCKET)
    N02 T01 M06
    N04 G43 H01 Z.1 M08
    N05 G01 Z0. F3.3369
    N06 G3 X.04 Y.196 Z-.05 I-.2188 J0
    N07 G3 X.04 Y.196 Z-.1 I-.2188 J0
    N08 G3 X.04 Y.196 Z-.15 I-.2188 J0
    N09 G3 X.04 Y.196 Z-.2 I-.2188 J0
    N10 G3 X.04 Y.196 Z-.25 I-.2188 J0
    N11 G3 X.04 Y.196 Z-.3 I-.2188 J0
    N12 G3 X.04 Y.196 Z-.35 I-.2188 J0
    N13 G3 X.04 Y.196 Z-.4 I-.2188 J0
    N14 G3 X.04 Y.196 Z-.45 I-.2188 J0
    N15 G3 X.04 Y.196 Z-.5 I-.2188 J0
    N16 G03 G17 Y-.196 I-.04 J-.196 F6.6738
    N17 G01 X1. Y0.
    N18 X.04 Y.196
    N19 X.09 Y.4409
    N20 G03 Y-.4409 I-.09 J-.4409
    N21 G01 X2.25 Y0.
    N22 X.09 Y.4409
    N23 X.14 Y.6859
    N24 G03 Y-.6859 I-.14 J-.6859
    N25 G01 X3.5 Y0.
    N26 X.14 Y.6859
    N27 X.19 Y.9308
    N28 G03 Y-.9308 I-.19 J-.9308
    N29 G01 X4.75 Y0.
    N30 X.19 Y.9308
    N31 X.24 Y1.1758
    N32 G03 Y-1.1758 I-.24 J-1.1758
    N33 G01 X5.04 Y-.196
    N34 G03 Y.196 I-.04 J.196
    N35 G01 X.24 Y1.1758
    N36 X.29 Y1.4207
    N37 G03 Y-1.4207 I-.29 J-1.4207
    N38 G01 X5.09 Y-.4409
    N39 G03 Y.4409 I-.09 J.4409
    N40 G01 X.29 Y1.4207
    N41 X.34 Y1.6657
    N42 G03 Y-1.6657 I-.34 J-1.6657
    N43 G01 X5.14 Y-.6859
    N44 G03 Y.6859 I-.14 J.6859
    N45 G01 X.34 Y1.6657
    N46 G00 Z.1
    N47 M09
    N48 M05
    N49 G91 G28 Z0.
    N50 M01
    (JOB 1  POCKET)
    (FEATURE POCKET)
    N51 T02 M06
    N52 G90 G54 X.35 Y1.7146 S595 M03
    N53 G43 H02 Z.1 M08
    N54 G01 Z-.5 F1.6685
    N55 G03 G17 Y-1.7146 I-.35 J-1.7146 F3.3369
    N56 G01 X5.15 Y-.7348
    N57 G03 Y.7348 I-.15 J.7348
    N58 G01 X.35 Y1.7146
    N59 G00 Z.1
    N60 M05
    N61 G91 G28 Z0.
    N62 T01 M06
    ( END OF FILE)
    ( END OF PROGRAM)
    N63 M30
  20. #40
    Nov 2010
    nice
    Thats nice SBC, how do i go about using your file?
Page 2 of 3 123
  1. Replies: 6
    Last Post: 04-30-2010, 01:55 AM
  2. There has GOT to be an easier way!?
    By HackMax in forum Benchtop Machines
    Last Post: 08-28-2009, 04:39 PM
  3. New easier CNC sulotion
    By roctech in forum Commercial CNC Wood Routers
    Last Post: 06-29-2009, 04:42 AM
  4. Which is better, easier?
    By dpmulvan in forum DIY CNC Router Table Machines
    Last Post: 10-31-2007, 05:55 PM
