588,205 active members*
4,100 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Open Loop to Closed Loop Stepper Conversion
Results 1 to 12 of 12
    Feb 2007
    6
    Hello, I am new to this group and have a question. I currently have a CNC router with stepper motors in an open loop configuration. I would like to add encoders and switch to a closed loop configuration. What type of controller is recommended for this? I am willing to build my own if plans/schematics are available.
    Thanks in advance,
    Ed
    One way, you can add a linear scale to your machine as a position feedbakc closed to your motion controller (e.g. PMC).
    Another way, by implementting high resolution encoders to update the motor position every 25 micro-seconds, closed-loop stepper drives ensure controled real-time position accuracy without lose of steps in open-loop stepper system.
    Go to Leadshine website for more product information
    Jun 2010
    eric can you give us a list of actions required for moving from open to closed loop stepper? I have a 3 axis router with rotary and got problems with losing stepps. I am going to solve it but dont know if change to servo or just add encoders. if adding encoders is possible with no need to any complicated electronics knowledge (I am not on it!) Its what I will do certainly.
    Closed Loop Stepper, Hybrid Servo Drives
    Quote Originally Posted by justbabak View Post
    Actually, it's hard to add the encoder to the stepper motor by yourself if you are not motor manufacturer for the airproof reason. As I said previous, you can add a linear scale to your machine closed to you motion controller. But this proposal will be charged much.
    Another way, you can use a existing closed loop stepper system (closed loop drive+motor) as a directly replacement of the current system. It combines the advantages of both servo system and open loop stepper. And it's cheaper than servo system. You can go to Leadshine website to get more product information. Reply this if you have other issues.
    Jun 2010
    seems good option, I checked website but I did not find any "closed loop stepper" thing. can you be more specific? thanks in advance.
    Hybrid Servo - Closed Loop Stepper
    Hi, Leadshine closed loop stepper products are named as Hybrid Servo Drives and Hybrid Servo Motors. (Hybrid Servo=Closed Loop Stepper) So check the website and find hybrid servo system products.
    Jun 2010
    ok, I checked it, sounds good, but there is one question, the encoder is absolute or relative? It is important because my problem with the current drive is that it makes a small dislocating movement upon power-on! so after a power failure or after each start-up of the machine, all the axes make a small move (between 0-0.2mm) unexpectedly so I have to adjust all the coordinates again.
    so I have to makes sure that the new drive system which I want to move on will solve this problem. does it solve it?
    Leadshine Hybrid Servo Product - Closed Loop Stepper
    I checked with Leadshine R&D and the hybrid servo(clsoed loop stepper) products only support relative encoder type now. The absolute type product is in the process.
    I have met some CNC machine maker which used the relative encoder before. All the axes of the machine will homing first after power-on to fix the problem you mentioned. I know it's unconvenience than absolute type.
    Jun 2010
    thanks Eric for shedding some light on this subject, now the conditions are more clear for me.
    It's OK. If you have further problem or have any interest with Leadshine hybrid servo(closed loop stepper) products, please kindly contact me at [email protected] or visit Leadshine Technology Co., Ltd. - the leading global motion control product manufacturer
    Jul 2007
    11
    What would be the best to replace IMS drives for steppers with US Digital encoders?I am turning a Beckman pipetter into a 3d printer.
    Sep 2012
    228
    Hello Leadshine Eric...
    If we are currently using Nema 34 Steppers rated at 960 oz holding torque... what model and specification drivers and hybrid stepper would your recommend. I have seen some rated at 2Nm but that seems like almost 1/3 of the power of a 960oz motor.
    Any advice?
    And if I wanted to go to a DC servo motor that had an encoder... what would you recommend then?
  1. CNC conversion typically open loop or closed loop?
    By foobar42 in forum Benchtop Machines
    Last Post: 10-30-2009, 01:21 AM
  2. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  3. Closed loop vs. open loop
    By pelesl in forum Benchtop Machines
    Last Post: 04-06-2007, 10:56 PM
  4. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
  5. Closed loop....open loop?
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 06-26-2004, 10:02 PM
