Originally Posted by
maver1ck
I don't want to side track you if you are sure you are on the right track, but I'm confused by what you described regarding the cable you plugged in. It is possible I misunderstood the series of events, but based on what I remember reading:
1) Initially you were getting a "Hydraulic Overload Alarm"
2) You changed a cable (described as for the screen)
3) After changing this cable the original alarm is gone and you now have an alarm indicating "Machine Hydraulic Pressure Switch"
To me, this would indicate the cable you changed is tied to the I/O, not a screen. If you try to clear or hide this alarm, are you able to see any other ones?
