Last weekend I did the aluminum trim on my 13 windows. This weekend I used the left over aluminum flashing to make an enclosure for the milling machine.
The front shield is in three pieces. The top rail spans the opening. The left and right shields can be removed, or the whole front is removable for access to the machine for setups.
The X and Y steppers got sheet metal splash shielding. I had to cut an opening in the right side shield for the X stepper, when the table is all the way to the right. The opening is covered by a "doggy door" that moves out of the way when the motor goes through the opening.
Todd F.
