Originally Posted by
tjd10684
OK so does anybody have an exploded view of this assembly? I have not disassembled anything since the day I got it so everything should be in the correct orientation. I cant verify this but I don't think it was doing this when I got it so it stands to reason over the year something like the thrust bearing may have worked its way loose. I have checked the gibs several times they seam to be good I get very little lateral deflection under heavy cuts and I did attempt my z test under what I thought to be both loose and tight conditions very little effect on the results so I put it back to what I think was just a little on the tight side.
So I guess these problems should be under the z stepper. So I guess I will be removing it tonight and checking all the screws for tightness. Thank you for responding here, I did contact Khai about the z issue evidently John had been copied. That was 8 days ago I have not heard back. Now I know your busy up there I just thought I would use the resources available to me, thats all.
