587,546 active members*
3,841 visitors online*
Results 1 to 7 of 7
    Jun 2009
    30
    spindle button F5 clockwise, but not for pwm spindle
    The F5 spindle button on the main screen is supposed to start the spindle in clockwise rotation. But I have a spindle with rpm control PWM. and clockwise is looking staight on the spindle motor from the bit side so it's actually counter clockwise when the F5 is used. I have to use th F4 spindle comand to get it to rotate properly and thats no problem. But I would like to manually run the spindle outside of the program. How can I add and F4 to the main screen?
    35538
    You need to open the screenset in a screen editor and change it.
    There are two screen editors available, and video tutorials on using them at ArtSoft USA - Home of Mach3 and LazyCam
    Jun 2009
    30
    Where on earth is the screen editor?
    The small box or vbs editor I have found from a drop down menu but where on earth is the screen editor that is used on the tutorial? The teacher does not open this editor in the tutorial but allready has it opened at the start.
    35538
    Jun 2009
    30
    Next stupid question
    Screen editor open,
    Blank,
    Open file, OK
    Where would you like to start looking?
    Somewhere on my computer!
    35538
    I think the video explains this, but I think there's a Default menu where you point to the Mach3 install folder.
    Jan 2008
    13
    Quote Originally Posted by protrackcorp View Post
    Screen editor open,
    Blank,
    Open file, OK
    the defaults set file location is...... C\:Mach3
    you can find sets to open in machscreen
  1. counter-clockwise vs clockwise arc problem
    By loedward22 in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2009, 05:56 PM
  2. Can spindle start when you hit the Z-axis button?
    By moldcore in forum Milltronics
    Last Post: 04-26-2009, 02:14 PM
  3. Replies: 10
    Last Post: 10-24-2008, 04:11 PM
  4. Interact 412 - CYCLE BUTTON RESTART SPINDLE
    By Zhales in forum Bridgeport / Hardinge Mills
    Last Post: 07-20-2007, 01:46 PM
