Originally Posted by
Laser Doctor
Well, if you actually lase for 8 hours a day, your hours are basically correct. Try measuring actiual lasing time. Time on only. You may only turn the laser on 4 hours in your 8 hour day. 210 days a year is hard pressed for days worked. So, you would be looking at approximately 840 hours of use. Like I mentioned, RF lasers last up to 20K hours. Yes, there is a larger expense in the purchase. Production companies, not hobbyists require these requirements. You are also correct for using less current. When you use less current the laser gas doesn't disassociate as quickly. The atomic O3 and O4 oxygen created is less than when driving the current through the gas harder. This is why a proper mixture of gas, along with the use of gold, can make a glass tube last around the 1000 hour range when the conditions are just right. Cooling is also that important. The cooler you keep the laser tube (no lower than 60 F) will also support longevity.
Good Question the Laser Doctor.
