587,193 active members*
2,444 visitors online*
Results 1 to 2 of 2
    Aug 2012
    Cool What do I need for milling?
    I have recently purchased a 9" Harrison lathe and I want to carry out some milling on it but not sure what I need as I am also new to general machining
    I have just purchased a vertical slide but I still need to get a lathe vice and holding bolts for it.
    However for the cutting side of things I have not got a clue, can you please help
    What type of Arbour do I need?
    Collects?
    Etc etc
    Your help for a newbie would be very much appreciated
    May 2005
    3920
    Quick and dirty would be to chuck the end mill in the three jaw chuck. The usual runout in 3 jaw chucks means that this isn't often acceptable as it wears the end mill fast. But it is possible and probably done more than many would like to admit to.
    The next option is to get a morse taper to ER collet assembly. A good one should have much better control over run out.
    I'm assuming you have a vertical slide with T-Slots, if so some operations can be done by bolting the part to the slide with "T" bolts.
    I'd like to suggest getting some basic shop manuals to help out with specifics.
    Quote Originally Posted by Dgrallying View Post
    Collects?
    Etc etc
  1. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
  2. Offset Chain Milling vs Path Milling
    By ynnek in forum Uncategorised CAM Discussion
    Last Post: 03-11-2009, 11:29 PM
  3. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum Community Club House
    Last Post: 06-30-2008, 03:23 PM
