Another possibility is use a board outline and use back and outline, and drill and out line if you just want to regenerate only drill or only back.
I THINK it takes its origin from the smallest x-y it finds, so if you use an outline together, it will find the same corner each time. If you do drill by itself, it will use the hole find the origin, not the edge of the track.
