587,955 active members*
3,542 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Ballscrew leaking coolant
Results 1 to 6 of 6
    Aug 2009
    19
    I have a couple FADAL machines and it is apparent the coolant through ball screw design doesn't work well over time. The screw itself is still good and works well, but the seals used to keep the coolant where it should be cut into the journal and eventually give way causing bearing failure. Is there a fix for this other than putting a whole new screw in and waiting for it to happen again? Is there a company that can just put a stainless steel sleeve over the journal area for an economical price? I hate to spend a grand plus just to have it happen over and over.
    Jan 2006
    64
    The best thing you can do is replace the thrust bearings and then route the cooler fluid to the spindle housing only. One of the worst ideas Fadal ever had.
    Hardly anyone really needs the screw cooling.
    Jan 2004
    3154
    Yup
    Bypass the ballscrew cooling
    www.integratedmechanical.ca
    Aug 2009
    19
    What kind of accuracy would I lose by bypassing the coolant? At "normal" speeds it should be negligible considering the screw bearing is constantly being oiled with the Bijur system?
    Apr 2009
    105
    We by-bassed ours a couple years ago and NO loss of accuracy. Circle interpolated holes are still nice and round.
    Still working in the "D".
    May 2005
    53
    I bypassed ours when the machine was only about a year old. Accuracy loss is zip. My Machinery Handbook lists the linear expansion per unit length per degree F. for steel as .00000633 at 68 deg. F. In other words, a 10.0 inch move at a 5 deg increase in temperature would be 10.0003
    I don't know if you could run the machine hard enough to raise the screw temperature 5 degrees. Bottom line- bypass the coolant line and sleep well.
  1. Coolant leaking into base
    By Machining in forum Haas Mills
    Last Post: 08-30-2018, 10:07 PM
  2. coolant tank lid leaking
    By R.DesJardin in forum Tormach Personal CNC Mill
    Last Post: 01-29-2009, 03:18 PM
  3. Leaking coolant reservoir
    By JTulley in forum Tormach Personal CNC Mill
    Last Post: 08-03-2008, 02:51 PM
  4. Haas TM2 Leaking Coolant
    By Chris Swier in forum Haas Mills
    Last Post: 06-21-2008, 03:57 AM
  5. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
