588,464 active members*
7,550 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport and Hardinge MK2 , cant home z-axis
Results 1 to 3 of 3
    Oct 2012
    if the z axis is bellow half way it runs down to the soft stop, if it is above, it runs up to soft stop, thats all it will do,
    how can you use the manual free wheel with out homing to reset soft stops ?
    1121
    Your question is incomplete. There is no such thing as a bridgeport and hardinge.
    What is the model and control on your machine?
    Oct 2009
    78
    Quote Originally Posted by tim.y View Post
    Sounds to me like you need to replace the Z axis encoder.
    Ron
  1. Hardinge CHNC 1 Power up machine home!
    By Machineit in forum Hardinge Lathes
    Last Post: 05-04-2015, 02:42 PM
  2. X axis won't home? Bridgeport Torq-Cut 22 DX-32
    By hrhoward in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2013, 12:32 AM
  3. Hardinge CS-51 x/z axis will not home
    By ZenoTech in forum Hardinge Lathes
    Last Post: 09-26-2011, 06:44 PM
  4. Bridgeport Explorer X Axis Not Repeating From Home Position
    By minton in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2010, 04:38 AM
  5. Hardinge Conquest won't home?
    By Jim Wilson in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2007, 05:44 AM
