587,172 active members*
3,354 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > TTS holder codes
Results 1 to 3 of 3
    Jul 2009
    147
    TTS holder codes
    I updated my SC to the latest revision but forgot to rename my tool table which is now overwritten.
    does anybody have the size codes for the TTS holders? I have ER 20 and the all of the set screw holders.
    Feb 2008
    389
    Quote Originally Posted by davidperry3 View Post
    The attached is a .txt file I use to build and save these as backup.
    Attached Files Attached Files
    Currently using SC7 Build 1.6 Rev. 64105
    Jul 2009
    147
    thanks that will save a lot of time.
  1. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  2. G codes M codes Mach3
    By eaglezsoar in forum Mach Software (ArtSoft software)
    Last Post: 02-04-2011, 12:38 AM
  3. Die alignment: To dowel the punch holder or the die holder first?
    By PhoenixMetal in forum Diemaking / Diecutting
    Last Post: 09-11-2010, 02:11 AM
  4. Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 05:27 PM
  5. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 01:41 PM
