I'll have to check the runout on my machine. I have broken plenty of endmills, but they have mostly been F-ups on my part, not just spontaneous breakage.
No offense but you did have the gearbox in high with the spindle going the correct direction right? I can't believe a .01" cut at 10 ipm would break your endmill, even with a little runout. The speeds I mentioned were for aluminum, what are you cutting? Are you plunging straight to depth or ramping in? Any coolant/lube?
Matt
