587,180 active members*
4,606 visitors online*
Thread: XZero CNC
Page 141 of 226 4191131139140141142143151191
Results 2,801 to 2,820 of 4515
  1. #2801
    Apr 2011
    178
    Quote Originally Posted by antonzedd View Post
    I thought if you were using 12v you don't need the resistor?
    Would like to clear this.
    I have try wiring like that this morning.
    Result are that i have the input at all time (LED Red)
    The LED on the switch does change from when it see the metal or not.
    Could you clarify that plz.
    Eric
  2. #2802
    May 2008
    4068
    If prox are hooked up without resistor, the light will come on when it is triggered . If hooked up with resistor it turns into a PNP with power in line till it is triggered.
    XZero cnc
  3. #2803
    May 2008
    4068
    ViperXZ , all 30mm rails and 5 inch travel Z axis. Closer to 6 inch travel now
    http://www.xzerocnc.com/forum/showth...machine-set-up
    XZero cnc
  4. #2804
    Apr 2011
    178
    Quote Originally Posted by gio666 View Post
    It trigger now on the led on card.
    Nothing between plus and input.
    But nothing happen in mach3
  5. #2805
    May 2008
    4068
    You have to set them up in mach3 , set as limit or home or both
    XZero cnc
  6. #2806
    May 2008
    4068
    ViperXZ 1 HP ER20 spindle will have lots of vids, them will do the same with 2.7HP spindle to show difference
    XZero cnc
  7. #2807
    May 2008
    4068
    XZero cnc
  8. #2808
    Apr 2011
    178
    Yes and nothing show in diagnostic page.
  9. #2809
    May 2008
    4068
    That is the new 5 inch 20mm Z axis
    XZero cnc
  10. #2810
    May 2008
    4068
    Ill have these ones set up tomorrow and will post all info on my forum
    XZero cnc
  11. #2811
    Apr 2009
    174
    Hi, George:
    My ball screw shrank during shipping? ...18mm
  12. #2812
    May 2008
    4068
    The bottom bearing house should be on the top
    XZero cnc
  13. #2813
    May 2008
    4068
    You still get almost 5 inch travel that way too, just set soft limit there or reverse bearing houses
    XZero cnc
  14. #2814
    May 2008
    4068
    This is how yours goes together
    XZero cnc
  15. #2815
    Apr 2009
    174
    ok, the ball nut at the top.
  16. #2816
    Apr 2011
    178
    George...
    You built mine with the ballscrew on bottom on mine too
  17. #2817
    Apr 2009
    174
    Quote Originally Posted by DiaLFonZo View Post
    George...
    I would have preferred a longer ballscrew ..... Since the new version
  18. #2818
    Apr 2009
    174
    George, another question:
    why the Z plate, your do not do a few mm longer? the alignment would be easier.
  19. #2819
    Apr 2009
    174
    and also a slightly wider.
    It would also be good, not hinder the screw head to place the spindle mount.:idea:
    The viperX is very easy to do the assembly, but, must modify the Z plate.
    The vast majority of buyers do not have the ability to George, for alignment.
  20. #2820
    Apr 2011
    178
    I don't find that an issue myself.
    The plate align almost by itself and my K2 mount bolt from the outside
    Eric - DiaLFonZo
    Sent from my cellphone using Tapatalk
  1. XZero CNC
    By gio666 in forum News Announcements
    Last Post: 04-30-2013, 05:53 AM
