588,666 active members*
6,678 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > What tool is best? Bevel/Chamfer
    I have some parts that have what I call a small 45 degree bevel on the edge, I think is called a Chamfer as well?
    What tool would you use to do such a think? and where would I get one? This would be used a on sherline, btw.
    Donald
    Jan 2004
    3154
    www.integratedmechanical.ca
    Mar 2005
    1136
    what is small? if its a integral dimension of the part, as per DareBee, if its just for finish and to the remove the sharp edge/burr, use a good file
    Sep 2005
    86
    I've been using these drill point end mills with decent results.
    http://www.wttool.com/c/10322200p
    They same me a tool change on some projects too.
