588,137 active members*
5,625 visitors online*
Results 1 to 3 of 3
    Nov 2010
    71
    E-stop and the Hobby CNC pro board
    Does anyone know how hard it is to hook-up an E-stop on a Hobby CNC 4-axis pro board? I'm using Mach3.
    Thanks Mike
    May 2012
    124
    You have pin holes that are labeled on the left of the board, or, the terminals for home and limit. I thnk theyre pins 12-15+GND If your machine is setup properly, you need 3 homing swithes and software limits, leaving you with one open terminal. You can hookup a normally open or normally closed (normally closed is better) and assign it in mach3 that that pin is your estop. Its in the port i/o settings. Plug in a switch, the terminals need no pullup resistor...Im using an arcade button.
    For me its X home = 12, Y home = 13, Z home = 14, Estop = 15. All switches are tied together to the GND terminal.
    That help?
    Nov 2010
    71
    Sure does, thanks for the help!
    Mike
  1. hobby pro board troubles
    By skylanehku in forum Hobbycnc (Products)
    Last Post: 08-17-2012, 10:56 PM
  2. Hobby CNC board on a taig?
    By cnctoolman in forum Taig Mills / Lathes
    Last Post: 09-03-2010, 02:21 PM
  3. Hobby CNC board Help
    By Nickford306 in forum Hobbycnc (Products)
    Last Post: 06-12-2008, 04:22 PM
  4. hobby cnc board
    By mendez in forum Stepper Motors / Drives
    Last Post: 12-22-2005, 05:51 PM
