Originally Posted by
wizard
Because stainless work hardens you need to keep the RPM to a minimal on your tooling and feed Fast enough to prevent rubbing the surface or having a flute cut the hardened surface. The surface will harden very quickly and if you hesitate may be difficult to penetrate with your end mills.
Second it is advisable to get a speeds and feeds calculator to help with beginning spindle speeds and feed rates. With stainless be conservative when it comes to spindle speeds.
Third it has already been mentioned but you need to keep the cutting area free of chips / swarf as the stainless chips are extremely hard. These hard chips will crack, chip and break end mills if recut. Thus the suggestion to blast the chips out of there. Cutter damage due to this problem is very serious with stainless steels.
Once a piece is damaged from work hardening it can be very difficult to save it. If the geometry allows it I've had success in the past for coming at the hardened area from the opposite direction. You may cut through the hardened area that way at the expense of an end mill, drill or whatever. If you are lucky. It is usually worth a try especially if you have to send the part out for annealing or need to have another cast. Which brings up another point, make sure the castings are annealed.
