588,025 active members*
4,810 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 3D MACHINE A CURVED SURFACE
Results 1 to 9 of 9
    Jul 2012
    BobCAD1.dwgMY BOSS WANTS THE 3D CUTTER PATH TO GO ACCROSS THE CURVED SURFACE WITH CONSISTANT STEPS IN BOTH X/Y AND Z DIRECTIONS. THE ONLY CHOICE I SEE IN THE 3D MACHINING THAT GIVES YOU CONSISTANT STEPS IS EQUIDISTANT BUT IT LEAVES A CUTTER PATH THAT LOOKS LIKE A ENVELOPE. HE DOESNT LIKE THAT. DOES BOBCAD V24 OFFER WHAT IM LOOKING FOR? THANK YOU IN ADVANCE. ROD
    Sep 2010
    145
    What version are you running now.
    Jul 2012
    V24
    Jul 2003
    1220
    Does the corner radius also need to follow the same tool path?
    Jul 2012
    NO, THE SCALLOP JUST NEED TO FRONT TO BACK AND HAVE EVEN SPACINGS AND DEPTH. I CAN SEND THE FILE I HAVE IF YOU NEED IT. THANKS ROD
    Jul 2003
    1220
    As I'm still using V21, I don't know if what you want can be done with your version of BobCAD.
    I'm sure there are many that could write a macro to do what you need.
    Attached is a VB program that I've written which will generate some code which you may be able to run and get the finish you require.
    Note: This tool path is TOOL CENTRE
    Attached Files Attached Files
    Jul 2003
    1220
    Looks like I'm trying to re-invent the wheel.
    I see in the BobCAD manual V21 has a feature where this tool path can be generated under 3D: More: Surface: Ruled. I would expect your version to have something similar.
    Mar 2012
    1570
    BobCAD CAM V24 doesn't offer a scallop based tool path. Your z level finish or planner tool path is an incremental step over. So the scallop will chance as the curve of the surface changes.
    You could use equi distance, but that tool path will offset it and change direction.
    The V21 did offer a ruled surface which offers a constant step over, but it's single surface only.
    Now instead of running the tool across the surface, it you ran it up the surface or down the surface then you would get a constant step over.
    upload pics
    If you change the direction of cut to go "up" the surface then the scallops on the part would stay consistent.
    photo sharing websites
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jul 2012
    THANK YOU ALL FOR YOUR HELP. I DID GET THE ANSWER I WANTED. BEFORE I WAS HIRED THE COMPANY CONTRACTED THE PART OUT. THEY WANTED MY PARTS TO LOOK THE SAME. I THOUGHT SINCE I AM NEW TO PROGRAMMING THAT I JUST NEEDED TO BE SMARTER.. LOL. I BELIEVE THE SOFTWARE DOES NOT OFFER THAT OPTION. THANKS AGAIN GENTLEMEN. ROD
  1. Making a curved surface
    By Megaplow in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-19-2011, 03:52 AM
  2. 2d pocketing along a curved surface?
    By cgjeff in forum Visual Mill
    Last Post: 11-18-2010, 02:01 AM
  3. Cutter for curved surface?
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 09-03-2010, 03:36 AM
  4. Curved Surface Toolpath
    By ehsanmax in forum Mastercam
    Last Post: 03-14-2008, 12:39 AM
  5. Engraving a curved surface?
    By wyobmf in forum Rhino 3D
    Last Post: 05-29-2007, 03:13 PM
